Do i need to remove crank pulley if timing if a teeth off?
Do i need to remove crank pulley to adjust timing belt if timing if a teeth off? cause i know i have to take valve cover off and upper timing belt cover off. but if i dont have to take the crank pulley and lower timing belt off, that will save me some time.cause i am just adjusting the belt ,not to replace the old one.
please advise. thanks
Re: Do i need to remove crank pulley if timing if a teeth off? (Powered by VTEC)
It would be best to take the crank pulley off so you can use the refference marks on the oil pump to put it back in time for sure.
no
unless you are removing and replacing the belt all together
remove the covers
TDC the crank pulley
then TDC the gear (s)
and have it
remove the covers
and have it
Re: Do i need to remove crank pulley if timing if a teeth off? (preludedriva)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">no
remove the covers
and have it</TD></TR></TABLE>
loosen the tensioner as well
remove the covers
1320london
07-29-2017 02:55 AM
toniandfredo
Honda Civic (2001 - 2005)
06-10-2007 06:28 PM
EG2Driver
06-15-2006 07:24 PM
