question about a block
Old May 29, 2008 | 04:36 PM
2fast4jdm's Avatar
Default question about a block
i have a gsr that was just built and installed. we ran the car and noticed oil coming out of the block right behind the dip stick. it seems to be a small steady flow of oil. someone suggested i weld it, kinda like a patch. has anyone had experience with this. will this be a safe solution to the problem? thanks for the help
Old May 29, 2008 | 08:04 PM
inspyral's Avatar
You mean it's leaking out of the dipstick tube? Those are press-fit if I remember correctly. You might want to consider some silicone sealant or epoxy rather than welding it. Whatever you do, make sure the area is thoroughly cleaned beforehand, since any amount of oil will affect the integrity of the fix.
Old May 30, 2008 | 10:56 AM
Freshdot's Avatar
Default Re: (inspyral)
no its not leaking out of the dip stick. the leak is coming from the actual block. there seems to be a hair line crack right behind where the dip stick is. i was told i could weld it shut because that area is not under a great amount pressure. what do you guys think?
Old May 30, 2008 | 06:59 PM
rdeezy78's Avatar
Default Re: (Freshdot)
good luck. Doesn't seem anyone knows much about as there were 66 views and only 3 posts.
jdmturboitr
Apr 13, 2010 07:18 AM
em1 Ziggy
May 12, 2006 11:08 PM
drintegra
May 1, 2006 10:45 AM
Mr HYDE
Welding / Fabrication
11
Jul 18, 2005 11:08 AM
Mr HYDE
Jul 12, 2005 06:31 PM
