ROD BEARING OIL CLEARANCE???
Old May 28, 2008 | 09:20 AM
grand champ's Avatar
Default ROD BEARING OIL CLEARANCE???
Hey
Im building a GSR for alot of boost. What do i want my clearnace's to be for my rod bearngs. Ive done alot of searching and cant seem to get a good strait answer and its not realy something i want to gambel with.
They are at 2thou three tenths now, i think that is gunna be to big as from what ive read most people are saying that 2 thou is about the bigest they would go??
Eagle h-beams if it matters, and a polished gsr crank.
Old May 28, 2008 | 09:27 AM
swapit's Avatar
Default Re: ROD BEARING OIL CLEARANCE??? (grand champ)
i usually set the rods .0017 to .0019
factory is .0013 to .0024
Old May 28, 2008 | 10:03 AM
so i should be good at 0.0023
Old May 28, 2008 | 04:26 PM
Anyone else car to input or am i good to go??
Old May 28, 2008 | 06:29 PM
Stealthmode Performance's Avatar
Default Re: (grand champ)
Check your factory specs for your engine and put it on the higher side of the spec. .0015 worked well for me, and I believe Earl (RIP) used to recommend .0016 (if my memory is correct)
Old May 28, 2008 | 10:20 PM
I phone acura and they have no clue what im talking about. They say all we can do is get you the right one by checking numbers on the rods and the crank and matching them to colors.
I said yeah, i know, i can do that to. Now do you want to find these numbers on my eagle rods please???
Then their like, "You cant use these bearings with aftermarket rods, you have to get aftermarket bearings"
Then they said "We dont have any specs at all"
Old May 29, 2008 | 07:24 AM
champLSinteg's Avatar
Many people shoot for the middle of the specs, .0015 to .0017. In my motor with the LS crank and eagle rods I went with tighter clearances of .0012 to .0013 and I have not had any issues at all. It has seen 9200 rpm plenty of times.
Old May 29, 2008 | 04:34 PM
blackeg's Avatar
Default Re: (champLSinteg)
i just used what the helms recommended. i think my mains were on the looser limit but all still within oem spec
Old May 29, 2008 | 09:36 PM
RC000E's Avatar
Default Re: (blackeg)
.0015 dead nuts all the time...that's all I ever set any motor. From my Larry (Endyn) influence days. That's what he builds all his Honda motors to, and I figured if it worked for him, it'd work for me. 9000rpm boosted, NA motors, doesn't matter.
Your clearances are certainly loose. That's good for a race motor with no break in, and something that gains a little from loosing a little friction, but I personally wouldn't be comfortable with a clearance that big on a rebuild. Cut the crank slightly and go with an oversize bearing.
turboman2.2
Mar 5, 2010 08:27 AM
srmofo
Jul 20, 2009 10:59 PM
irishflame27
Oct 3, 2008 06:05 PM
Phoenix1
Dec 5, 2005 02:48 PM
GruvyTune
Jul 7, 2002 05:05 PM
