acl rod bearings on eagle rods?
Old Mar 3, 2010 | 07:17 PM
turboman2.2's Avatar
Default acl rod bearings on eagle rods?
i am going to be running ls crank, i know that the main bearings are the same in all b series, but the rods differ. I have eagle rods part number :5394, i believe they are gsr. Should i get gsr acl race bearings, or ls???? I read somewhere that you need to retang the rod to use gsr bearings if its and ls rod??
Old Mar 3, 2010 | 08:50 PM
zedron's Avatar
Default Re: acl rod bearings on eagle rods?
You cant use GSR rods with a LS crank I am afraid to tell you.
Old Mar 3, 2010 | 08:57 PM
vwbased's Avatar
have a nice day
Old Mar 5, 2010 | 08:14 AM
i ended up getting hx acl for the rods with .001 extra oil clearance, and standard crank bearings.... do you think i will be ok?????????
Old Mar 5, 2010 | 08:27 AM
kyden's Avatar
we can't tell you. you have to measure it.
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
boostedb20z
Apr 19, 2008 06:19 PM
b20vtech
Dec 6, 2007 09:07 AM
turbo boost
Jan 23, 2007 05:19 PM
loudassVTEC
Aug 2, 2006 03:55 PM
