Would downshifting waste gas?
Old May 28, 2008 | 09:10 AM
MegaPower's Avatar
Default Would downshifting waste gas?
Generally speaking, for most car
For example, say if i down shift from 3gear(3000rpm) to 2gear(~4rpm?)
Is it going to waste more gas due to the rpm goes up?
Or not, cause I didn't step on the gas?
Old May 28, 2008 | 09:25 AM
blkegcoupe's Avatar
From: ....................................................................................................
i don't know i always wondered it? but i don't always down shift cause im too lazy to brake lol
Old May 28, 2008 | 09:47 AM
sleeperrex's Avatar
Default Re: Would downshifting waste gas? (MegaPower)
No, when you are downshifting it cuts off and fuel for the engine and creates a vaccuum in the injectors in order to bring down rpms
Old May 28, 2008 | 09:49 AM
Ice78transam's Avatar
Default Re: (blkegcoupe)
Generally, fuel consumption is related to throttle position.
Old May 28, 2008 | 10:47 AM
team_exceed's Avatar
Default Re: Would downshifting waste gas? (sleeperrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperrex &raquo;</TD></TR><TR><TD CLASS="quote">No, when you are downshifting it cuts off and fuel for the engine and creates a vaccuum in the injectors in order to bring down rpms</TD></TR></TABLE>
So, even match revving wont have a negative affect on gas huh? I always questioned myself for doing it, wondering if Higher RPM's would mean more gas consumption. Nice to know its not like I thought.
Old May 28, 2008 | 10:57 AM
OMGWTFBBQ!'s Avatar
If you're touching the throttle to rev match when you down shift then yes, if your just letting the clutch rev match for you, then no, but your clutch probably isn't a big fan of you doing that all the time.
Old May 28, 2008 | 02:14 PM
drSquish's Avatar
I try to balance using the motor and brakes to stop. If my brakes are starting to wear out, I down shift more often to help out the situation. Otherwise, I'd rather use the brakes to keep my tranny in better shape
Old May 28, 2008 | 02:22 PM
obuhmyuh's Avatar
Default Re: (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam &raquo;</TD></TR><TR><TD CLASS="quote">Generally, fuel consumption is related to throttle position.</TD></TR></TABLE>
true, but you need to keep engine load under consideration as well.
Old May 28, 2008 | 03:14 PM
OMGWTFBBQ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">I try to balance using the motor and brakes to stop. If my brakes are starting to wear out, I down shift more often to help out the situation. Otherwise, I'd rather use the brakes to keep my tranny in better shape</TD></TR></TABLE>
If your brakes are wearing out, you should probably go buy new brakes. They cost like $30 and it takes less than an hour to change the front pads.
Old May 28, 2008 | 04:05 PM
Schister66's Avatar
Man U FTW
Load and throttle position are what effect your gas mileage. This is an obvious over-simplification, but you get the point.
Old May 28, 2008 | 04:20 PM
bigsyke's Avatar
what about injector pulse? a higher RPM will it not spray more fuel/time?
Old May 28, 2008 | 04:34 PM
DarkGenesis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MegaPower &raquo;</TD></TR><TR><TD CLASS="quote">Generally speaking, for most car
Or not, cause I didn't step on the gas?</TD></TR></TABLE>
When you down shift without stepping on the gas. You are not wasting any type of gas. Unless you plain to heel-to-toe then that's a different story.
Old May 28, 2008 | 06:52 PM
strategy400's Avatar
Default Re: Would downshifting waste gas? (DarkGenesis)
It depends on the accumulated length of time the ECU makes the injectors spray fuel
Old May 28, 2008 | 07:00 PM
TeamRPM_ZC's Avatar
2500 for my EG coupe, (EJ2) primor, has a sohc vtec zc
Old May 28, 2008 | 07:12 PM
elektronsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">I'd rather use the brakes to keep my tranny in better shape</TD></TR></TABLE>
Old May 28, 2008 | 08:29 PM
Frozen E's Avatar
H-T White Ops
Default Re: (bigsyke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke &raquo;</TD></TR><TR><TD CLASS="quote">what about injector pulse? a higher RPM will it not spray more fuel/time?</TD></TR></TABLE>
Nope, no throttle + negative load on the engine = no fuel being burned
Old May 28, 2008 | 10:09 PM
bigsyke's Avatar
Default Re: (IslandSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi &raquo;</TD></TR><TR><TD CLASS="quote">
Nope, no throttle + negative load on the engine = no fuel being burned</TD></TR></TABLE>
what i said was actually in response to this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Load and throttle position are what effect your gas mileage. This is an obvious over-simplification, but you get the point. </TD></TR></TABLE>
If your @ 5k cruising in 2nd, your hardly on the throttle. But if your going the same speed say 1k in 5th, you will be at a higher load/throttle, but less injector pulse. So where do you find the sweet spot?
Old May 28, 2008 | 11:12 PM
obuhmyuh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkGenesis &raquo;</TD></TR><TR><TD CLASS="quote">
When you down shift without stepping on the gas. You are not wasting any type of gas. Unless you plain to heel-to-toe then that's a different story.</TD></TR></TABLE>
heel-toing or at least rev-matching is the best way to downshift. if you're just engaging the clutch while in gear with out matching your tranny speed with your engine speed, you just asking for your clutch to wear out prematurely.
i usually only downshift if im gonna gas it through a turn or on-ramp, and have some fun. but other than that, i'd rather go through some pads then overhaul my tranny. brake's are there for stopping/slowing.
Old May 29, 2008 | 11:55 AM
bigsyke's Avatar
brand new pads are only $37 from honda! Brake away!
Old May 29, 2008 | 01:15 PM
blk92_d16's Avatar
Such a long thread for simple answer! LOL
Old May 29, 2008 | 01:31 PM
Artifactr's Avatar
Default Re: (blk92_d16)
I'm not sure if it's really so simply.
If load stays the same, and the engine runs at higher RPM than previous gear, then it will use more gas over time.
If you are rev-matching, then throttle is being used, and you are using gas there.
If you pull out of one gear, coast or brake to slow down, and then run a lower gear at the same previous RPM, this would be the way to not be using any more gas.
Old May 29, 2008 | 02:08 PM
Midori Bandit!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke &raquo;</TD></TR><TR><TD CLASS="quote">brand new pads are only $37 from honda! Brake away!</TD></TR></TABLE>
Civic_07
Mar 11, 2008 04:28 PM
w0ng_sta
Jun 16, 2006 05:04 PM
SiHatchTurbo
Sep 29, 2003 11:48 AM
The real Isaac
Nov 11, 2002 05:45 PM
