Question about shifting
I just wanted to know if shifting a little earlier has any effect to the engine?...and what are the pro/cons of shifting earlier/later. And also if it does save gas?
Re: Question about shifting (Civic_07)
yes shifting early saves gas... the later you shift the more gas you waste because they are higher rpm's and your making the engine work more
Re: Question about shifting (Midori Green)
BUT if u shift so low that ur boggin its bad for gas to because you have to press the accelorator further. IMO gas mileage depends more on throttle position....if you use 1/4 throttle all the way to redline you will get bettter mileage that if u were to shift way low and have the pedal to the floor. corrct me if im wrong?
Re: (Civic_07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_07 »</TD></TR><TR><TD CLASS="quote">My friend said it would flood the engine?...im guessing flood it with gas?...or like use excessive gas?</TD></TR></TABLE>
your friend is lying you control the gas your car consumes with your right foot
nY's FiNeSt
26
10-03-2003 05:30 AM
