turbo B16 hesitating...
Old May 27, 2008 | 05:34 AM
steinbacheg6's Avatar
Default turbo B16 hesitating...
Hey ive got a 95 si coupe with a boosted B16. at first i thought it was only when the engine was cold, but sometimes it jsut happens all the time... as im driving a feel a slight hesitation, and if i get into boost it really hesitates and jerks back and forth a bit... it did this the whole ride home last night (was about 5 degrees celcius) could it just be the cold? at first i thought it was the clutch slipping cause its still teh stock one(new one on the way) but this morning it boosted just fine once it was nice and warm...
Old May 27, 2008 | 06:35 AM
sorrule's Avatar
what kind of mods do you have or is it just a bolt on turbo to a stock motor? Maybe your timing is off or you are detonating? Check your spark plugs maybe they are fouled. Don't really know till you give more details.
Old May 27, 2008 | 07:27 AM
motor is stock. timing belt was just done end of last season. precision sc61 turbo with custommanifold and 2.25" exhaust, turbonetics wastegate, blitz BOV. B and M FPR. greddy 440cc injectors. walbro 255 fuel pump. running 9psi
Old May 27, 2008 | 10:14 AM
Ghost_K20a's Avatar
what are you tuning with?
what are you pulling for timing as you get into boost?
Sounds like you have enough fuel, sounds like a timing problem. But not 100% sure..
i guess well start with your tune! post that up if you even know what it is.
Old May 27, 2008 | 11:57 AM
i dont know anything about that kind of stuff i jsut know its tuned on uberdata. I think within the next short while i will get a re tune to get everything to 100%
Old May 27, 2008 | 02:22 PM
Ghost_K20a's Avatar
Default Re: (steinbacheg6)
that is prolly the best idea ive heard all day.
Which leads me to think its a tune issue.
good luck on getting it fixed, report back when you get it running right again and tell us what went wrong.
Old May 27, 2008 | 07:06 PM
sorrule's Avatar
If the tuning issue doesn't work, do you have a fuel pressure gauge? A couple friends of mine had trouble with the B&M command flow FPR not working properly so maybe check that out too.
Old May 28, 2008 | 05:33 AM
yes i have a fuel pressure gauge..under the hood tho... what should it be at at idle?
Old May 28, 2008 | 09:19 AM
sorrule's Avatar
someone correct me if I'm wrong but around 40ish psi at idle
JDM IN MY SOL
Jun 25, 2011 12:54 PM
adubaz7
Aug 16, 2007 06:12 AM
Leef9turbo
Aug 7, 2007 06:21 PM
blackcrx16
Jul 15, 2007 11:55 AM
SCsol
Jul 29, 2001 08:28 AM
