car cut out and wont start
hi guys im from ireland i have a 95 eg coupe with dc2 typer engine in it, was drivind along and the engine check came on so turned car off and back on and the car just died as if ran out of petrol. got car back to house did ecu flase and got code 41, found the problem it being broken wire in dizzy fixed it but car still ait startin have good comp,full spark and loads of fuel any ideas!!!!????????
Did the CEL go away afer you made the repair? Did you reset the ECU? The CEL should come on with the fuel pump cycle when the key is in the "run" position and after the pump shuts off, so should the CEL if not you might still have a problem.
BOOSTEDgreeneg
09-15-2005 07:27 PM
