nfp vw bug @ breakaway track
Old May 22, 2008 | 05:31 PM
nf performance's Avatar
Default nfp vw bug @ breakaway track(video inside)
test & tune @ breakaway track
http://www.youtube.com/watch?v=RdMiU846Aus
Old May 22, 2008 | 06:28 PM
USDM mullet's Avatar
Default Re: nfp vw bug @ breakaway track(video inside) (nf performance)
1/8th mile track? 2380cc?
Old May 23, 2008 | 04:34 AM
Default Re: nfp vw bug @ breakaway track(video inside) (USDM mullet)
2180 cc
Old May 24, 2008 | 02:39 AM
hyn_boi808's Avatar
what kind of cam are you running in the car?
Old May 24, 2008 | 06:01 AM
Default Re: nfp vw bug @ breakaway track(video inside) (hyn_boi808)
It's a fk-89 with 1.5 ratio rockers.
Old May 24, 2008 | 05:23 PM
ALL IMPORT's Avatar
nice 2 see some more bug action!!!!!!!!!!!
Old May 25, 2008 | 08:13 AM
Default Re: nfp vw bug @ breakaway track(video inside) (ALL IMPORT)
Old May 26, 2008 | 09:02 AM
OldskoolVW's Avatar
what did that thing leave the line on the 2 step at...like 7500 rpm?? sounded pretty high.
Good to see you guys making progress with the car. Took mine out two weeks ago and found out a 1.31 fourth gear is to tall for the 1/4 so I got a 1.21 and a new pro ring to get some more mile an hour.
Old May 26, 2008 | 06:55 PM
Default Re: nfp vw bug @ breakaway track(video inside) (OldskoolVW)
Why is a 1.31 to high? What ring are you running and what kind of power are you pushing if you don't mind? And yes my 2step had the wrong pill in it, it was a 8000 chip.
Old May 27, 2008 | 02:45 AM
OldskoolVW's Avatar
we run 1/4 mile and the trans gears are 3.88 ring and pinion, 3.78 first 2.21 second gear 1.58 third and 1.31 fourth. Motor makes about 210 horse power, car weighs 1420 with me in it and currently hits the rev limiter set at 8000 rpm right at the 1000 foot cone. So with the changeto a 1.21 I hope to get the all the way to the finish line before bouncing off the rev limiter.
However we pulled the trans apart and the pro ring I have in there is a 8 tooth gear and the new one is a 10 tooth gear. So I hope it works. If not I need to find another.
Old May 27, 2008 | 03:30 AM
ALL IMPORT's Avatar
here is our bug up at Georgia it was 38degrees out. cold as hell. we dorve up fri night sat morning it was snowing & sun we raced. couldnot believe we drove up thier for snow. lol
fastest we ran yet due to the cold ran a 8.97 + 153mph
now we are running 9.0 9.2 consistant with only 630whp at 2050lbs
http://youtube.com/watch?v=iEQ...lated
Old May 27, 2008 | 03:59 AM
Well with that kind of weight yes the 1.21 you will see a big different in mph and with that 1.58 third that 1.21 will be perfect hope it works for u
Old May 27, 2008 | 04:03 AM
my buddy back in the virgin island had 13b in 67 bug that **** was voilent
Old Jun 4, 2008 | 05:25 AM
ALL IMPORT's Avatar
we have seen them on the internet but none at the track cause the stock tranny cant hold much power & the high reving but it is deffinatly fun
Old Jun 4, 2008 | 06:07 AM
yeah he was using a ranco trans axle
96_civic_EX
Oct 12, 2010 10:57 PM
civicjdmb16a
Mar 25, 2009 05:12 AM
Cor ey
Oct 3, 2004 09:44 PM
streetlvlhatch
May 11, 2004 10:49 AM
SIXTYdashONE
Jun 13, 2003 10:25 AM
