running like crap, codes p0170, 0172
Old May 19, 2008 | 03:26 PM
d15bdelsol's Avatar
Default running like crap, codes p0170, 0172
anywhere under about 3500rpm it feels like its bogging down real bad the codes say system too rich and fuel trim malfunction, a few weeks ago it also said cylinder one misfire so i got new plugs and ngk wires, cap and rotor, and it ran a little better but still it has no power at low rpm, it seems like its starved for fuel or flooding out, when i get on it and hit second it shoots a black cloud out the exhaust so i know its got to be really rich. any body have any idea whats wrong?? its a 98 five speed 140,000 mi. it also has a aem cai and i just bought a new filter so its getting enough air also changed the fuel filter today and erased the codes. i listened to the exhaust closely at idle today and it sounds like its miss firing on a cylinder or something and the exhaust stinks bad so maybe a clogged cat? but i don't think it would be the cat cause it still runs fine at high rpm please help!!!
Modified by d15bdelsol at 7:46 PM 5/20/2008
Old May 20, 2008 | 03:10 PM
Fongman's Avatar
have you check you vaccum lines? have you pull out the plugs and see which one is wet? are the firing order right? have you check compression?
Old May 20, 2008 | 06:48 PM
d15bdelsol's Avatar
Default Re: (Fongman)
no i haven't done any of those, the plugs havent been wet but definitly rich. i did the wires one at a time so i know the firing order is still corect. and i don't have anything to do a compression check
Modified by d15bdelsol at 9:35 PM 5/20/2008
ahayden
May 20, 2015 04:39 AM
mitchh29
17
Mar 10, 2013 10:06 AM
Integra4lyfe069
Dec 13, 2011 05:47 PM
sheBangZ
Oct 3, 2006 11:51 AM
teg2000gs
Sep 16, 2004 06:40 PM
