Hondata updates tunes library with another 40 base maps
Old Jul 14, 2002 | 11:28 PM
Hondata's Avatar
Default Hondata updates tunes library with another 40 base maps
Hondata has added 40 base maps to its existing library of 30 tunes. (a total of 70 for those that cannot count)
We have recalibrated each of the stock Honda maps for D16z, B16A, B17A B18C and B18A for 240, 440, 550 and 800cc RC injectors.
Tuning for full throttle is easy. The newly added base files files have been calibrated for part throttle, which is usually the hardest and most time consuming part of the tuning process. Full throttle tuning usually only deals with about 15 - 20% of the fuel and ignition map. Part throttle deals with the other 80-85% which is usually the hardest to get right. Part throttle is where you spend most of your driving time.
In addition the fuelling and ignition curves have been recalibrated for all boost levels up to 29 lb, based on feedback from many top tuners around the US. Tuning for boost has just become a lot easier.
These files should save you considerable tuning time and maintain your stock starting and drivebility when you switch to bigger injectors.
More info available at http://www.hondata.com/tunerlibrary.html
Any stage 4 user that has not been contacted about this already needs to call us about being put on the mailing list.
Doug
Old Jul 14, 2002 | 11:33 PM
SIK IN DA HED's Avatar
New User
Default Re: Hondata updates tunes library with another 40 base maps (Hondata)
Old Jul 14, 2002 | 11:45 PM
Sonny's Avatar
Sonny
Old Jul 14, 2002 | 11:59 PM
turbocoupe's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (Sonny)
Damn nothing for the D16 turbo yet. . .hopefully that will change soon, or until I get my *** into gear.
Old Jul 15, 2002 | 01:07 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Doug
Man... That is so freakin awsome! I can't wait to get mine put in!!
Old Jul 15, 2002 | 01:58 AM
Mr. Softee's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (Snafu-Si)
still no love for the non-vtec
Old Jul 15, 2002 | 03:20 AM
PrecisionH23a's Avatar
i plan on running the 4b in my turbocharged '94 obd1 h23a with the obd1 p75 LS ecu. I was told i would be given a base map to get the car cranked, however i cant find anyone with a map that is running 720cc injectors. Can you guys help me out at all? Thanks.
Old Jul 15, 2002 | 05:44 AM
Speed PHreak's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (94goldjungsr)
Word, us Zdyne users get the shaft as well. I've converted a few hondata tunes over to for use with Zdyne SECU. but ti would be nice to get ahold of some of those B18A base maps.
Old Jul 15, 2002 | 06:33 AM
KCHybrid's Avatar
Old Jul 15, 2002 | 07:43 AM
SiRkid's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (KCHybrid)
Old Jul 15, 2002 | 02:32 PM
Hondata's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (GudeH23a)
Email me and I will send you a 800cc injector map for a F22. That should get you started with a few small adjustments.
Doug
Old Jul 15, 2002 | 02:44 PM
marklamond's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (turbocoupe)
I would get something developed for the D16 turbo quick as you like but nobody wants to sell a Hondata to me over here in the UK. not fair
Doug, can you help?
[Modified by marklamond, 11:46 PM 7/15/2002]
[Modified by marklamond, 11:48 PM 7/15/2002]
Old Jul 15, 2002 | 02:47 PM
MaxBoost's Avatar
New User
Hey Doug which base map would you use for a b18c1 with JunIII cams, skunk manifold, i/e/h, and b16 pistons with rings?
Old Jul 15, 2002 | 05:08 PM
Halo's Avatar
Default Re: Hondata updates tunes library with another 40 base maps (MaxBoost)
I have a 12:5:1 built crvtec setup using a "mugen" chipped P28 and RC 310's. Which stage would you recommend? Obviously since I am na the boost option is unnecessary. I have been closely looking at the stage 2, but can I get away with using the stage 1?
Old Jul 16, 2002 | 09:30 AM
doug, you have
mRek9R
Sep 5, 2005 09:57 PM
Aeka GSR
Apr 28, 2004 09:26 AM
Pritos
Jan 27, 2002 01:07 PM
GruvyTune
Nov 1, 2001 02:02 PM
