Adjusting Greddy Type-RS BOV
Old May 15, 2008 | 07:20 AM
ImPuLsIvE's Avatar
Default Adjusting Greddy Type-RS BOV
I've noticed that my BOV is leaking boost past ~6psi. Which way should I adjust it so that it remains closed like it's supposed to?
Any help would be greatly appreciated.
Thanks!
Old May 15, 2008 | 07:21 AM
chimmike's Avatar
Default Re: Adjusting Greddy Type-RS BOV (ImPuLsIvE)
should be an adjustment screw on top, screw it in a little bit
Old May 15, 2008 | 07:22 AM
ImPuLsIvE's Avatar
So screwing it 'harder' (tee-hee) would be the correct way then?
Old May 15, 2008 | 07:46 AM
chimmike's Avatar
Default Re: (ImPuLsIvE)
that's right.
There's generally a fine line where crossing it makes the turbo surge....so be careful. Generally if it holds the boost fine and doesn't leak out, you're okay. It'd be nice to be able to test on a dyno, spray it with soapy water or put a balloon on it while boosting in a gear just to see if it opens, ahah.
Old May 15, 2008 | 08:11 AM
ImPuLsIvE's Avatar
excellent. I'm scheduled to go for dyno tuning next week-ish, so I'll test it out then to make sure all is well. I've tightened it about 1/4-1/2 turn from what it was, so hopefully that does the trick.
Thanks again!
Old May 15, 2008 | 08:13 AM
chimmike's Avatar
enjoy it
4dek
Jun 1, 2008 05:39 AM
GEN2 LS
Mar 10, 2008 05:39 PM
Jayboy
May 12, 2005 10:57 PM
tegon-gsr
Apr 7, 2005 07:02 PM
Ri5e
Nov 3, 2001 10:10 PM
