downpipe bolts on garrett turbo keep coming loose, pissing me off please help
Old May 10, 2008 | 01:47 PM
91_civicsi's Avatar
Default downpipe bolts on garrett turbo keep coming loose, pissing me off please help
anyone know what i can do to keep the bolts on my downpipe/turbo to stop from vibrating loose, it keeps happening and its annoying as [freak] turbo is a garret .57 / .63
3" downpipe custom made, its an eg h22 euro r hatch
thanks
Old May 10, 2008 | 01:55 PM
Dartanian's Avatar
Default Re: downpipe bolts on garrett turbo keep coming loose, pissing me off please help (91_civicsi)
Try these: http://www.nord-lock.com/
Old May 10, 2008 | 01:56 PM
thatdannyboy's Avatar
take to a welding shop and have them tack it once after you tighten it. but to remove you have to grind the tack so make sure everything is where you want it.
Old May 10, 2008 | 02:10 PM
GSROWNSU's Avatar
tack welds are definately not needed. I have the same turbo and a 3" down pipe and for my hardware i used allen head bolts with splined lock washers. That's the trick is to use splined lock washers...and then just tighten the hell out of them. I've had my car going for almost 3 weeks now and put about 1000 miles on the setup and nothing has come lose
Old May 10, 2008 | 02:12 PM
SpoolnG2's Avatar
Default Re: (GSROWNSU)
Or theres always the old V-Band
Old May 10, 2008 | 02:32 PM
shortyz21's Avatar
Default Re: (SpoolnG2)
bolts are crap.
just slap some studs in there.
then use these nuts, the same ones as honda uses on there exhaust manifold.
u can buy them from mcmaster carr, just a diff type of locknut
Old May 10, 2008 | 03:08 PM
91_civicsi's Avatar
thanks for the replies guys! im gonna try using lock washers for now if that works great if not can i use thread sealant? like lock tight or whatever, that blue gooey **** or w/e
would that work?
Old May 10, 2008 | 04:05 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">bolts are crap.
u can buy them from mcmaster carr, just a diff type of locknut </TD></TR></TABLE>
Old May 10, 2008 | 04:28 PM
jewjew bean's Avatar
Default Re: (full Circling)
I have the same problem. I'm using studs with lock washers and it doesn't work. Definitely need to get some of those lock nuts
Old May 10, 2008 | 04:49 PM
ironcheftony's Avatar
http://www.atpturbo.com/Mercha...e=FST
Old May 11, 2008 | 10:50 PM
transpro's Avatar
Default Re: (ironcheftony)
studs and flange nuts. the nord-locks couldn't hurt either
Old May 12, 2008 | 04:43 AM
Mikey3000's Avatar
Default Re: (91_civicsi)
spring lock washers don't work, use locknuts.
Old May 12, 2008 | 12:22 PM
Bakeoff's Avatar
Am I the only one that just uses a bolt? No washer... Never come loose. Just crank em tight and go... Three years on some of the bolts without them moving.
Old May 12, 2008 | 12:56 PM
extralargenog's Avatar
Default Re: (Bakeoff)
safety wir4 that ish
Old May 12, 2008 | 01:35 PM
Maxcapacity's Avatar
USe the allen keyed round head bolts. I have a custom 3" down pipe on my Garret turbo, 1 1/2 years and no looseness. I have had to pull them off a few times to get to other stuff but still they do not come loose.
Are you using hex style bolts? those I used on my turbo to manifold and they came loose alot, even with lock washers so I used thread locker on them also.
Old May 12, 2008 | 02:01 PM
adrian1281's Avatar
Old May 12, 2008 | 03:16 PM
HamiltonRex's Avatar
Default Re: downpipe bolts on garrett turbo keep coming loose, pissing me off please help (adrian1281)
vband here.. ftw!!
Old May 12, 2008 | 03:32 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bakeoff &raquo;</TD></TR><TR><TD CLASS="quote">Am I the only one that just uses a bolt? No washer... Never come loose. Just crank em tight and go... Three years on some of the bolts without them moving.</TD></TR></TABLE>
I use bolts too. I don't have the clearance for studs and nuts.
Old May 12, 2008 | 04:34 PM
Silva Bullit DC4's Avatar
Default Re: (Dartanian)
Nord-locks here.
Old May 12, 2008 | 06:52 PM
NJIN BUILDR's Avatar
If your using a gasket get rid of it and use a film of high temp rtv.These will also do the job http://www.stage8.com/
Old May 12, 2008 | 11:41 PM
Wideopentuning's Avatar
Default Re: downpipe bolts on garrett turbo keep coming loose, pissing me off please help (NJIN BUILDR)
This stuff works great! http://www.034motorsport.com/p...d=609
Old May 12, 2008 | 11:57 PM
da_dude's Avatar
Never had any problems with the bolts coming loose on the downpipe.
TravisBiggie
May 10, 2012 04:26 AM
patrick4588
Jun 29, 2007 09:33 PM
zexifiedlude
Nov 27, 2005 07:48 PM
Mario.
Feb 1, 2005 06:02 PM
austrian type-R
Apr 19, 2002 07:56 AM
