1995 civic problem
hi to all-i am new here. i have a 1995 civic automatic with 180,000 miles. generally runs well,however,at 1500-1800 rpm engines shakes a sputters. clears up around 2000 rpm and seems to run fine. changed cap and rotor-no fix. also speedo goes crazy-works when it wants to and sometimes goes well over 120 miles an hour will cruising 40-45. any help is greatly appreciated.
does it do the shaking in every gear? could be an alignment issue/ball joints etc. as for your speedo, id reccoment checking the wires to see if theres a short, also you may want to check your vehicle speed sensor
