problem with speed odometer
Old Jun 19, 2003 | 01:11 AM
vtNaMeSe's Avatar
Default problem with speed odometer
i was wondering if anyone can help me out with a little problem my speed odometer only works sometime when it feels like it . . . my rpm meter works fine just my speed odometer is not really working right i was wondering if it was the wiring or should i just replace it with a new cluster
Old Jun 19, 2003 | 06:01 AM
Martaigne's Avatar
Default Re: problem with speed odometer (vtNaMeSe)
Check your VSS plug on top of the tranny housing.
Old Jun 19, 2003 | 08:08 AM
fluxion's Avatar
amin n'rangwa edanea
Default Re: problem with speed odometer (Martaigne)
yah i had the same problem, it would spike every now and then and sometimes just sit there till eventually it completely stopped working. I got so many ****** speeding tickets after that =\ I had to replace the vehicle speed sensor (the mechanical unit in the transaxle.) It's about $40 at a junkyard and you shouldnt have any problems afterward.
Old Jun 19, 2003 | 12:32 PM
vtNaMeSe's Avatar
Default Re: problem with speed odometer (fluxion)
i already replace my speed sensor and i still have the same problem
Old Jun 19, 2003 | 02:55 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtNaMeSe &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if anyone can help me out with a little problem my speed odometer only works sometime when it feels like it . . . my rpm meter works fine just my speed odometer is not really working right i was wondering if it was the wiring or should i just replace it with a new cluster</TD></TR></TABLE>
Probably needs a new speedo head. The speedometer and odometer both run off the same signal.
Old Jun 20, 2003 | 07:55 AM
civicboisi's Avatar
im having the same problem too...i got a speedosensor off an auto tranny...would that fit and work the same?
Old Jun 20, 2003 | 04:07 PM
CaMiKaZi's Avatar
thanks for info
mine does samething i will go and buy speed sensor and see what it will do
Old Jun 21, 2003 | 06:55 AM
YeuEmMaiMai's Avatar
Default Re: problem with speed odometer (civicboisi)
yes why wouldn't it?
vedha
Oct 9, 2009 09:46 PM
one slow coupe
Nov 30, 2006 12:30 PM
sensorsearch
Aug 18, 2004 04:52 PM
gatoracer
Jan 14, 2003 05:52 PM
