Where do I route the coolant return line?
Old Apr 30, 2008 | 08:56 AM
hatchling37's Avatar
Default Where do I route the coolant return line?
I have a sandwich tee off the front water neck on a D16Z6. It has two ports on it (with included plugs). Can I just loop it through the turbo and back to the T, or do I have to run the return elsewhere? TIA from a FI noob.
Old Apr 30, 2008 | 10:08 AM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
I have a -6 fitting welding to the water pump pipe behind my block for the feed, the front water neck i'm using for the return.
Old Apr 30, 2008 | 10:16 AM
Default Re: (Mr. Anderson)
Nice. That sounds like a mighty fine idea. What kind of metal is the water pipe?
If anybody else has suggestions, I'd love to hear them. (Hoping to avoid welding, but certainly not out of the realm of possibility)
Old Apr 30, 2008 | 10:47 AM
a1320addict's Avatar
Default Re: (hatchling37)
Have you thought about picking-up off the front freeze plug and returning to the radiator?
Effective, and cost-effective concerning fittings and lines as it's the shortest method possible IMO.
Old Apr 30, 2008 | 01:31 PM
welfarepc's Avatar
Default Re: (a1320addict)
you think there is enough pressure in the block to force the coolant through the turbo and up to the upper rad hose?
seems like the water pipe is the best ticket.... but im open to options!@!
Old Apr 30, 2008 | 04:56 PM
notoriousB's Avatar
Default Re: (welfarepc)
I use the line that used to go to the throttle body as the feed and the return line from the IACV as the return. No problems so far and no welding required. (bypassed the TB & IACV coolant flow)
Old Apr 30, 2008 | 08:58 PM
B R Fittings's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">Have you thought about picking-up off the front freeze plug and returning to the radiator?
Effective, and cost-effective concerning fittings and lines as it's the shortest method possible IMO.</TD></TR></TABLE>
Bingo!!
Old Apr 30, 2008 | 09:13 PM
agrn93ls's Avatar
that would be the proper way, the water is pumped from the water pump through block up through the head and out the upper hose into the radiator
the water pipe on the coolant tube in the back is return into the pump, you need to come off the positve flow side of the pump, block or head
Old Apr 30, 2008 | 09:15 PM
agrn93ls's Avatar
Default Re: (B R Fittings)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B R Fittings &raquo;</TD></TR><TR><TD CLASS="quote">
Bingo!!
damn nice looking hoses and routing
Old May 1, 2008 | 07:21 AM
Default Re: (agrn93ls)
Just so the OP has a full idea on how everything comes together
Old May 1, 2008 | 09:39 AM
IN VTEC's Avatar
Default Re: Where do I route the coolant return line? (hatchling37)
We have a 4294R that uses M18x1.5 on the center housing and converted to a -8AN flare.
We used a 3/8" NPT to -8AN flare off of the VictorX manifold and a another M18x1.5 to -8AN flare adapter on the thermostat housing in place of the fan thermoswitch.
The fan thermoswitch got tossed because the fan relay is wired to constant on.
You can also do this and still retain a coolant temp threshold for fan activation if you have the S300 (or other standalone) and wire an output with conditional activation.
Old Jun 6, 2008 | 03:54 PM
dpetro1's Avatar
Default Re: Where do I route the coolant return line? (IN VTEC)
bumping this from last month. is everyone running the return to the top of the radiator? i think ive seen some people using the bottom as well. any advantage of where you weld the bung on the radiator?
Old Jun 9, 2008 | 08:38 PM
dpetro1's Avatar
Default Re: Where do I route the coolant return line? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">bumping this from last month. is everyone running the return to the top of the radiator? i think ive seen some people using the bottom as well. any advantage of where you weld the bung on the radiator?</TD></TR></TABLE>
bump. i know there are a bunch of gt-r turbos on this board
Old Jun 9, 2008 | 09:38 PM
1995Civic's Avatar
Bingo!!
This looks freakin awesome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">http://i147.photobucket.com/albums/r...t/DSC03016.jpg
http://i147.photobucket.com/albums/r...t/DSC03017.jpg
http://i147.photobucket.com/albums/r...t/DSC03018.jpg
Just so the OP has a full idea on how everything comes together </TD></TR></TABLE>
Thanks for the in depth pics...helped me out
Old Jun 10, 2008 | 08:16 AM
96 GSR-T's Avatar
I welded a Bung right at the bottom of my radiator for the return, total line length is less that 1'.
Old Jun 10, 2008 | 10:05 AM
1995Civic's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">I welded a Bung right at the bottom of my radiator for the return, total line length is less that 1'.</TD></TR></TABLE>
I'm thinking about doing this as well...seems like an easier route to take.
Old Jun 10, 2008 | 11:33 PM
NAEGH22's Avatar
is there any difference between doing the return on the top or bottom of the radiator?
Old Jun 11, 2008 | 07:07 PM
1995Civic's Avatar
Default Re: (NAEGH22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAEGH22 &raquo;</TD></TR><TR><TD CLASS="quote">is there any difference between doing the return on the top or bottom of the radiator?</TD></TR></TABLE>
I'm pretty sure it just has to do w/ the length of the line you'll need. Other than that, I can't see there being any other difference.
Old Jun 11, 2008 | 07:32 PM
JDMCRX's Avatar
Default Re: (1995Civic)
Only thing i can see being on the bottom is the heat from the center cartridge will be transfered into the line going to the bottom of the rad and will not be cooled off and go back into the motor. But i dont think it s big deal. I would do it to the top if it was my car.
Old Jun 12, 2008 | 07:39 AM
96 GSR-T's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">Only thing i can see being on the bottom is the heat from the center cartridge will be transfered into the line going to the bottom of the rad and will not be cooled off and go back into the motor. But i dont think it s big deal. I would do it to the top if it was my car.</TD></TR></TABLE>
How much coolant do you think passes through a -6 line? I have heard some stuff a long time ago about GT Coolant Lines overheating cars but I sure as hell have not experienced it. I am running a 1/2 Radiator blocked by a huge Intercooler in 95+ Deg heat and I am not overheating.
GT500FTW
May 6, 2013 01:48 PM
megomaniac
May 19, 2011 05:57 AM
h23vtec_dc2
Feb 28, 2010 04:47 PM
Rubixcu7
Jul 11, 2005 08:27 PM
sPaRk'iT
Oct 16, 2004 05:06 PM
