02-04 or 05-06 K20A??
Old Apr 29, 2008 | 05:22 AM
dc5 when i ride's Avatar
Default 02-04 or 05-06 K20A??
ima bout to do a k20a swap in my dc5 but im wondering what year should i get? is there a big difference between those years. both has 220 hp etc... you guys tell me what you think?
Old Apr 29, 2008 | 09:17 AM
Tyte-S's Avatar
Default Re: 02-04 or 05-06 K20A?? (dc5 when i ride)
Newer ones might tend to have less miles on them...
Old Apr 29, 2008 | 10:05 AM
caseyjck20's Avatar
k20a2 02-04 has 200hp
k20z1 05-06 has 210hp, better headers, slightly higher compression, better cams...similar to type R, better transmission (carbon coated synchros) shorter 5th
k20a jdm type-r 220hp same as k20z with lsd and slightly higher compression and diff intake mani
a2- $3-4000
z1- $4-4500
a- $5500-6500
go with the z1 motor as i have a 05 type s its the ****!
Old Apr 29, 2008 | 10:46 AM
blueshark123's Avatar
Default Re: 02-04 or 05-06 K20A?? (caseyjck20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caseyjck20 &raquo;</TD></TR><TR><TD CLASS="quote">k20a2 02-04 has 200hp
a2- $3-4000
z1- $4-4500
a- $5500-6500
go with the z1 motor as i have a 05 type s its the ****! </TD></TR></TABLE>
All k motors only have one header and the compression between both motors are the same.
Old Apr 29, 2008 | 11:19 AM
SkankyEJ7's Avatar
Where did you get that information....
Old Apr 29, 2008 | 01:53 PM
caseyjck20's Avatar
Default Re: 02-04 or 05-06 K20A?? (SkankyEJ7)
oops i meant higher comp on the r vs us spec.
point is why buy a type r motor for 1500 more when all u get is .5 more comp and a lsd. just make shur u dont buy the jdm k20a from the type s integra has only 160hp seen people get riped off befor.
Modified by caseyjck20 at 3:00 PM 4/29/2008
Old Apr 29, 2008 | 03:31 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5 when i ride &raquo;</TD></TR><TR><TD CLASS="quote">ima bout to do a k20a swap in my dc5 but im wondering what year should i get? is there a big difference between those years. both has 220 hp etc... you guys tell me what you think?</TD></TR></TABLE>
Lean towards the '05-'06, majority of them tend to have low miles (as stated above) and is still in pristine condition.
Correct me if I'm wrong, but the weight of both of the years are quite similar to each other? I don't want to search for that information, but if correct then it all comes down to what you like best (i.e. headlights, tail lights, gauge cluster, and wheels).
Old Apr 29, 2008 | 03:39 PM
Pat_S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caseyjck20 &raquo;</TD></TR><TR><TD CLASS="quote"> just make shur u dont buy the jdm k20a from the type s integra has only 160hp seen people get riped off befor.</TD></TR></TABLE>
Stop spreading misinformation. It's the Base model you're talking about, not the Type-S.
Old Apr 29, 2008 | 03:45 PM
WhiteOnRice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caseyjck20 &raquo;</TD></TR><TR><TD CLASS="quote">just make shur u dont buy the jdm k20a from the type s integra has only 160hp seen people get riped off befor. </TD></TR></TABLE>
GTFO
Old Apr 29, 2008 | 04:08 PM
Tyte-S's Avatar
Default Re: 02-04 or 05-06 K20A?? (WhiteOnRice)
He's 100% right...Talk about putting your foot in your mouth...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caseyjck20 &raquo;</TD></TR><TR><TD CLASS="quote">oops i meant higher comp on the r vs us spec.
Modified by caseyjck20 at 3:00 PM 4/29/2008</TD></TR></TABLE>
Third one down.
Modified by Tyte-S at 5:18 PM 4/29/2008
Old Apr 29, 2008 | 05:22 PM
That's annoyingly stupid.
And...
Old Apr 29, 2008 | 05:48 PM
Tyte-S's Avatar
Default Re: (WhiteOnRice)
^^lol. Yeah, it is dumb how they all are labeled the K20a.
Old Apr 29, 2008 | 05:49 PM
Tyte-S's Avatar
Default Re: (Tyte-S)
Time to start counting some exhaust cam lobes.
Old Apr 29, 2008 | 06:42 PM
Dc5Typ3S12's Avatar
a2- $3-4000
z1- $4-4500
a- $5500-6500
YeS, Sir
Old Apr 30, 2008 | 04:27 PM
og seany b's Avatar
Default Re: 02-04 or 05-06 K20A?? (Dc5Typ3S12)
Im not sure about the 02-04 but i still have the window sticker when my 05 was new and its rated at 210 hp.
Old Apr 30, 2008 | 05:05 PM
Tyte-S's Avatar
Default Re: 02-04 or 05-06 K20A?? (og seany b)
Yes, '05's were rated at 210 and they dropped the '06's back down to 200.
Old Apr 30, 2008 | 06:18 PM
SkankyEJ7's Avatar
Default Re: 02-04 or 05-06 K20A?? (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">Yes, '05's were rated at 210 and they dropped the '06's back down to 200.</TD></TR></TABLE>
When did they start making them to the engine rating with all of the accessories on? Wasn'tit around 06 when they released the new Si's and rated them at 197.
Old Apr 30, 2008 | 06:34 PM
I think that was 2006.
I wish they'd just measure it at the wheels already.
Old Apr 30, 2008 | 08:32 PM
bukydc5's Avatar
well i got a k20a.(05') and i got 200whp. and it was dino tuned. /i/honata k pro.
Old May 2, 2008 | 06:35 PM
Tyte-S's Avatar
Default Re: 02-04 or 05-06 K20A?? (bukydc5)
"The engine intake and exhaust modifications that boost the power of the 2005 Type-S model to 210 hp (157 kW) at 7800 rpm (revised to 201 hp (150 kW) in 2006), compared to 200 hp (150 kW) at 7400 rpm on the previous model. "
96_GsR_BlownEngine
Aug 28, 2012 05:59 AM
EKHWhat
Feb 23, 2007 07:18 PM
EG type GTR
Jul 28, 2006 11:41 PM
Al-sonic
12
May 24, 2006 04:33 PM
CHK4TIX
Aug 19, 2003 06:02 AM
