Cant Split the case on my D-series
Old Apr 28, 2008 | 06:16 AM
92BluEH-3's Avatar
lulz
Default Cant Split the case on my D-series
Alright im trying to get the case to split on my d-series tranny and i can slide he housing and box apart only about an inch but then it just gets hung up on something. Ive read about a counter shaft c-clip but only found info for it on b transmissions. Is there one on the d-series and how the hell do i get it off?
Old Apr 28, 2008 | 02:04 PM
hatchling37's Avatar
Default Re: Cant Split the case on my D-series (92BluEH-3)
There is one on the D also. You have to take out the large sealing plug at the top (opposite end of the exposed mainshaft) of the case. Put your 3/8" ratchet in there and remove it. Then you have to get a pair of snap ring pliers or a couple of flat blades and spread that beotch apart. Then once it's expanded, tap the case and it should come off with minimal monkeying.
Old Apr 28, 2008 | 06:00 PM
92BluEH-3's Avatar
lulz
Default Re: Cant Split the case on my D-series (hatchling37)
Yea i figured that out i just seen that plug and i thought hell its worth a shot. and whaddya know there it was.
oh and thanks for being intelligent and not a d-bag, like most of h-t
Old Apr 29, 2008 | 07:56 AM
1992Si's Avatar
Also check the sticky at the top of this forum.
Old Apr 29, 2008 | 08:01 AM
92BluEH-3's Avatar
lulz
Default Re: (1992Si)
ahhhh my bad i musta missed it
six7one
Sep 23, 2006 01:47 PM
hondaj05
17
Jul 3, 2006 01:19 PM
DC_RaceR
Mar 7, 2006 04:18 PM
crexer
Oct 4, 2004 06:00 PM
nsxmatt
Jun 4, 2003 07:26 PM
