How hard is it to put EX cluster in a DX?
I've got a 94 DX and would like to put in an EX cluster with the tach. Is there anything major that needs to be changed? Does it plug right in or do I have to run wires for the tach like a normal aftermarket one?
U serious? That is awesome. All this time I figured I would have to rewire something to get the tach to work. If I knew it was this easy it would have been done a while ago, b/c I couldn't find a place to mount my small aftermarket tach without it looking ghetto.
you could take off the condoms on the bulbs to make it brighter. its alot bright than stock. youll notice the difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">no you take the dx out and you plug in the ex no wiring everything is plug and play. even the Si cluster.</TD></TR></TABLE>
will this work with a 97? I wanna do this to my EK cause i dont wanna resort to an aftermarket tach. Anyone know if theres a write-up on how this stuff wires up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 »</TD></TR><TR><TD CLASS="quote">96-00 clusters are interchangable as well the tachs are pre wired...you can also swap in the older crv clusters</TD></TR></TABLE>
great! now i just have to figure out how it all hooks up and im good to go. No tach kinda sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apotheosis »</TD></TR><TR><TD CLASS="quote">
Very easy, maybe like 3-4 plugs. The connectors should be different too so it makes it easier to install.
</TD></TR></TABLE>Very easy, maybe like 3-4 plugs. The connectors should be different too so it makes it easier to install.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">
Very easy, maybe like 3-4 plugs. The connectors should be different too so it makes it easier to install. </TD></TR></TABLE>
alright cool. thanks
This diy works good for the amber bulbs. It has that jdm amber look. I did it to my bulbs after I swapped my ex cluster in.
https://honda-tech.com/zerothread?id=661308
yankeefan855
May 15, 2010 03:55 PM
snarcher!
Apr 7, 2008 11:42 AM
89 EF Si
Mar 14, 2005 08:53 AM
Plug and play for the win
