Noobs ls/vtec BUILD. =D
Old Apr 24, 2008 | 01:10 PM
gsrcrazy's Avatar
Default My ls/vtec BUILD. =D
its a basic build...
b18a block bored and honed...
gsr head...resurfaced, 3 angle valve job, tapped for ls/v
arias 11.5:1 c/r
eagle H beam rods..
b18a crank..
stock gsr cams..and cam gears for now..
eGay 4-1 header w/ 2 1/2 collector..
original replacement Felpro ls head gasket.
new gsr oil pump..
22t water pump..w/ gsr timming belt..
and best of all.. =D .. S300 =D
dyno graph soon! what do u guys think it'll put out? 170???
Modified by gsrcrazy at 2:22 PM 4/24/2008
Modified by gsrcrazy at 1:29 AM 4/30/2008
Old Apr 24, 2008 | 01:22 PM
b20vtech's Avatar
Default Re: My ls/vtec BUILD. =D (gsrcrazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrcrazy &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by gsrcrazy at 2:19 PM 4/24/2008</TD></TR></TABLE>
is it me or ur cylinder walls look a little scored up?
Old Apr 24, 2008 | 01:26 PM
gsrcrazy's Avatar
Default Re: My ls/vtec BUILD. =D (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">
is it me or ur cylinder walls look a little scored up?</TD></TR></TABLE>
yea.. i had started to assemble the short block and before i put the oil pan on...i was like wtf...balancing...lmao... so i took the rotating assembly back off and took it to get balanced... so im guessing those lines are cause of the rings scrapping against the cylinder walls... it is a fresh bore and hone so.. yea...
oooh...u know what caused those lines...just remembered... when i measured the bore after the bore and hone...i measured it to do my ring end gaps...lol.. so those lines are cause of the tool used..
Modified by gsrcrazy at 2:42 PM 4/24/2008
Old Apr 24, 2008 | 02:47 PM
American.Graffiti's Avatar
More updates.
Old Apr 29, 2008 | 07:34 PM
gsrcrazy's Avatar
do u guys think i'll be amazed w/ the power difference...going from full bolt on stock gsr... to 11.7ish:1 c/r....tuned lsvtec??? hehe... i just cant wait!
my old gsr.. .it came a long way.. ...
Old Apr 29, 2008 | 07:46 PM
jontsi95's Avatar
jus lettin you know im building a similar motor (compression ratio wise) and i was going to rock gsr cams for awhile too but a fellow h-techer brought to my attention that gsr cams run the risk of detonation on a high compression motor because they dont have enough overlap to vent the cylinders not sure if its true for your motor but i figured id let ya know b4 u throw em in and have problems but for ls vtec
Old Apr 29, 2008 | 07:52 PM
gsrcrazy's Avatar
wow..really... im gonna search on that... thanks for letting me know... i just want this motor running already..lol... but i'll look into it...thnx..
anyone else heard of this?
Old Apr 29, 2008 | 10:25 PM
b20vtech's Avatar
Default Re: (gsrcrazy)
i hope it doesn't end up like that again
Old Apr 30, 2008 | 12:27 AM
gsrcrazy's Avatar
Default Re: (b20vtech)
i hope it doesn't end up like that again </TD></TR></TABLE>
i hope not...lol..
well what do you all think?? this setup w/ stock gsr cams for like 3 months til i get sufficient funds and wont stay broke..lol.. tuned and all.????
Old Apr 30, 2008 | 01:58 AM
ef92b's Avatar
nice build you're into.
i'm in the same boat as you man! click my sig.
building it slow though. shipping costs and time's killing me.
Old May 5, 2008 | 01:51 AM
gsrcrazy's Avatar
so i finally got everything back from the machine shop... measured all my bearing clearances. and made me happy .=D
they were all perfect (within specs)
now i have to pick up a piston ring compressor to finish my bottom end..ready to slap on my head. =D
Old May 5, 2008 | 03:00 AM
ef92b's Avatar
don't forget to install those pistons correctly.
crown notch is on the intake side.
have fun!
Old May 5, 2008 | 01:31 PM
quicksilver1689's Avatar
i ♥ snails
your going to upgrade those gsr cams eventually?
Old May 5, 2008 | 11:08 PM
gsrcrazy's Avatar
Default Re: (quicksilver1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">your going to upgrade those gsr cams eventually?</TD></TR></TABLE>
for sure..im kinda leaning towards the buddy clubs..
Old May 6, 2008 | 12:03 AM
gsrcrazy's Avatar
random flick of the bottom end..
98GSR-Turbo
Oct 14, 2008 09:22 AM
delslow94
Mar 1, 2003 12:24 PM
spettinger
Feb 12, 2003 03:10 PM
AndyL
Jun 18, 2002 10:59 AM
