LS trans problem
Old Apr 20, 2008 | 02:28 PM
trixr's Avatar
Default LS trans problem
i just recently bought a a1 tranny for my ls and put it in. The problem is that i seem to only have 1,2,5 gears. it feels like its going into 3rd and 4th but it is acting like it is just in neutral. any ideas or is it a shot trans
Old Apr 20, 2008 | 02:51 PM
Sliced Beard's Avatar
Default Re: LS trans problem (trixr)
Without tearing it apart, I would assume that it is a broken shift collar or stripped out dog teeth or maybe even a broken shift fork. You could even be having a problem with the selector mechanism that activates the shift fork, but I doubt the mechanism is the culprit doe to the fact that all of the other gears work.
Honda uses a conventional shift companion setup.
1-2 use the same shift collar and shift fork and are on the input shaft
3-4 use the same shift collar and shift fork and are on the countershaft
5-R use the same shift collar but the reverse gear is operated by a linkage mechanism activated by a second appendage off of the 5-R shift fork shaft. The reverse gear does in fact have a synchronizer located at the very outside of the the countershaft.
Old Apr 20, 2008 | 06:41 PM
trixr's Avatar
so no matter what it is it needs to come off the car?
Old Apr 20, 2008 | 06:47 PM
Default Re: (trixr)
I would most definately say so. I can fix it for you but you would have to pay for shipping/transit and parts, I would be EXTREMELY reasonable with the labor.
Old Apr 20, 2008 | 06:49 PM
Default Re: (DirtySol)
Something like that would be fairly simple for me. I would not have to do any shimming or resetting of any tolerances. Pretty much pull it apart, assess the damage, order parts and reassemble. I would not cahrge any more than 100 bux as long as you pay for all of the parts and shipping.
Old Apr 20, 2008 | 07:41 PM
trixr's Avatar
are any of those parts able to break from installation or would it be from who i bought it from
Old Apr 20, 2008 | 08:26 PM
Default Re: (trixr)
it is just a simple part failure issue. I would think that it would be from some sort of abuse if the shift collar is the actual culprit. If the Shift fork is broken, then I would just blame it on part failure.
Bend-it
Honda Fit
Dec 4, 2013 03:15 PM
92hatchboi
Oct 22, 2007 06:13 PM
sohc prelude
Feb 26, 2006 07:26 PM
WONG FRIED RICE
Apr 17, 2003 09:05 AM
