problems with installing head
Old Apr 19, 2008 | 07:09 AM
daniel990836's Avatar
From: born and raised in norcal, livin in houston, tx, 77073
Default problems with installing head
ok heres the problem we finished reinstalling the head gasket the head torqued the bolts to 22ft lbs in the certain order required then after torqeing then to 22ft lbs we went to 53 ft lbs. so that was done. now lol... we forgot to place the #1 piston to TDC will i have to remove the head again and do everything all over? any help would be appreciated. thank u
Old Apr 19, 2008 | 07:22 AM
superfast666's Avatar
Default Re: problems with installing head (daniel990836)
no just before u put the timing belt on set the bottom end to top dead center
Old Apr 19, 2008 | 07:58 AM
Default Re: problems with installing head (superfast666)
cool thanks bro and i wish i was back in cali lol
Old Apr 19, 2008 | 08:47 AM
i did that and its wierd because i have a d16z6 and i put the cranshaft to TDC. then aligned the camshaft. but the distributor or the rotor isnt lining up with #1 piston u know what i mean? its set to #3 what can ido?
Knots
Feb 26, 2018 12:24 PM
HackeN
Jul 19, 2006 06:23 PM
ham
Jul 8, 2006 08:46 PM
duckmanEG
Nov 5, 2004 11:25 AM
MIKES
Jun 14, 2002 08:39 AM
