HOW important are the dowels in the head?
Old Jun 14, 2002 | 07:56 AM
MIKES's Avatar
Default HOW important are the dowels in the head?
I put on my head and torqued it down, slapped in my cams, set my timing and put on my timing belt. Now when I look in the box from my engine builder I see one of the dowels to line up the head to the block. I have one in it already but I didn't see the other one until I already installed the head. Is this a accident waiting to happen or am I fine without the one? I also have ARP head studs that I have torqued down to 75 ft pounds of torque. What should I do?
Old Jun 14, 2002 | 07:59 AM
Speed PHreak's Avatar
Default Re: HOW important are the dowels in the head? (MIKES)
Trust me you want both, with out them there is no way for you to properly line up the head gasket.....
Old Jun 14, 2002 | 08:05 AM
MIKES's Avatar
Default Re: HOW important are the dowels in the head? (Speed PHreak)
That dowel I have in the back and the head studs not good enough? How much more movement is there?
BoOsTeD_eK's Avatar
very important...under load the head can budge...and if you are running domed pistons...your valve might just start banging your piston.
Old Jun 14, 2002 | 08:11 AM
MIKES's Avatar
Default Re: HOW important are the dowels in the head? (BoOsTeD_eK)
**** man. Is my head gasket still good? I have not put the motor in the car yet so its not that bad. Just time and my labour.
Old Jun 14, 2002 | 08:23 AM
supergreenNA1's Avatar
New User
you shouldn't re-use the head gasket once it's been crushed.
Old Jun 14, 2002 | 08:39 AM
X2BOARD's Avatar
Default Re: HOW important are the dowels in the head? (supergreenSol)
Do it right the first time or don't do it.... if it breaks you will cry....
SlowPokeEg
Mar 22, 2008 09:10 PM
Tigfab
Jun 3, 2007 03:04 PM
austincrx
Sep 7, 2006 09:49 AM
Day-DayC
May 18, 2006 08:51 PM
b18cx
Jun 10, 2004 03:31 PM
