is this dent bad?
Old Apr 15, 2008 | 01:38 PM
Scud's Avatar
Default is this dent bad?
i just got a junkyard turbo and when i recieved it it had a little dent.. just wondering if the dent will cause problems? thanks!
[IMG][/IMG]
[IMG][/IMG]
Old Apr 15, 2008 | 02:15 PM
97grnrs's Avatar
Default Re: is this dent bad? (Scud)
as long as the seal is ok.. does it look messed up where the housing meets the cast part? i would take the plate off and hammer it flat and bolt it back on.
Old Apr 15, 2008 | 02:28 PM
turbodano's Avatar
Default Re: is this dent bad? (97grnrs)
Looks like a Volvo turbo you got there. I would say it needs to be checked to make sure it did not bend the seal plate. If you sent it to a rebuilder a good used seal plate is like 20 bucks.
Old Apr 15, 2008 | 02:57 PM
Scud's Avatar
Default Re: is this dent bad? (turbodano)
yea it is an old volvo turbo im gonna use for my b18b. the seal doesnt look broken so i think im good.. but do you know of a reputable rebuilder? i wouldnt mind to see how much it would be to get a rebuild.. thanks!
Old Apr 15, 2008 | 04:09 PM
97grnrs's Avatar
more than u can buy a new one of them turbo for usually. unless u do it your self.
Old Apr 15, 2008 | 04:40 PM
Scud's Avatar
well i mean i have some mechanical knowledge but how hard is it to rebuild myself? and since it is such an old turbo where could i find a rebuild kit for it? thanks!!
Old Apr 16, 2008 | 04:15 PM
Scud's Avatar
ttt
Old Apr 16, 2008 | 05:21 PM
civicjoe's Avatar
I think that when you rebuild them you are supposed to precision balance the turbine shaft as turbos spin at hella fast rpms. That requires a special machine and stuff.
Old Apr 16, 2008 | 08:52 PM
andoxviii's Avatar
I thought Volvo used Mitsubishi turbos?
chocolatesk8er10
Nov 25, 2008 08:14 AM
Jason703Racing
Aug 2, 2006 04:01 PM
OutLuDeD
Oct 14, 2003 09:16 PM
flip1199
Nov 20, 2002 08:07 PM
93LSivic
Mar 11, 2002 02:20 PM
