Look at my turbo now!
I got the turbo last week or 2 ago. I decided that it needed a facelift. Looked like this before..........
And then after about 6-7 hours of mostly hand sanding and some polishing tonight, it now looks like this......
What do you think? Not bad for my first time. As you can see the cast on the housing was really rough. I couldnt really sand inbetween the lettering and there was some deep pits I couldnt get into either. I think I did a good job though!
Gonna do my manifold and downpipe too. They /hopefully/ should be here tomorrow.
Banned
Re: Look at my turbo now! (newgsr)
Dremel with 3/4in sanding drums to remove pits/scratches
40 grit sand paper
200 grit sand paper
320 grit sand paper, wet
400 grit sand paper, wet
600 grit sand paper, wet
buffing wheel w/ emory rouge compound
buffing wheel w/ white rouge compound.
40 grit sand paper
200 grit sand paper
Well, actually not all hand sanding. I cheated a bit with an air die grinder and some a white roloc disc. But hand sanded after that (5+ hours worth) with 260, 540, 1000, 1500 wet sand paper. Then good ol Home Depot polishing kit ($12) on my cordless drill--using the white stick.
I hope to have on soon as soon as I buy my hondata 3B, which im buying this week, and some RC 550s.
You know I will post pics and let everyone know when its on!
Re: Look at my turbo now! (rjardy)
i did my friends and just used a wire wheel and then a polishing wheel..... came out pretty damn good too...
it was alot nicer looking before touching it with dirty oily hands... we were puttin ghte car back together so nothing was really clean...hehe...
New User
Re: Look at my turbo now! (ED9Hybrid)
yeah I'm amazed what you can do with a wire wheel - I polished my max rev manifold real quick (5 min) with a wire wheel on the Makita and it looks pretty decent... when I "de-turbo" for smog I'm going to polish everything up.
New User
Re: Look at my turbo now! (93LSivic)
Looks great! Nice polishing job. I need to learn how to do that
when you "wet sand" do you just add water, or soak the paper in water, or what?
-Xerxes
-Xerxes
Re: Look at my turbo now! (Xerxes)
whenever i "wet sand" anything i just dip the paper in water.. im pretty sure other people do it other ways.... wire wheel ownz
I just did the sanding in my laundry rooms plastic sink. The wetsand keeps the fine paper from loading up with whatever it is your sanding.
Like I said this was my first time polishing. Just take your time. Its not hard at all, just time consuming--and it also helps to have some of the right tools.
Re: Look at my turbo now! (lswithvtec)
i used one similar to this one and this one they work well.... and these things to polish
[Modified by ED9Hybrid, 3:12 PM 3/11/2002]
Re: Look at my turbo now! (tararan)
a friend used a wire wheel on his valve cover but didnt use the polishing wheel so it stayed scractched and didnt look so good....
.RTErnie
Welding / Fabrication
18
02-19-2006 01:03 PM
