Misfire in all 4 But runs fine
Old Apr 10, 2008 | 08:26 PM
JLeeBB4's Avatar
Default Misfire in all 4 But runs fine
It misfire in all four cylinders but it runs fine. I cant even feel the hestiation like a normal misfire does. My CEL Blinks every Now-and-then during highway driving.
-Firing order correct
-New plug wires
-New distributor from distributor king
-CEL all 4
-Dont think head damage......Baby the car
-H22a 4gen
-Just had my timing checked
NGK plug with 6000 miles on them......Dont think its the plugs
Old Apr 10, 2008 | 08:58 PM
nemesis25's Avatar
Default Re: Misfire in all 4 But runs fine (JLeeBB4)
Flashing CEL means you're running rich, I believe. It usually happens when The ECM detects misfire.
Old Apr 10, 2008 | 09:20 PM
JLeeBB4's Avatar
So your saying 02 sensor maybe
Old Apr 11, 2008 | 05:55 AM
Acidcrakker's Avatar
Default Re: (JLeeBB4)
coil pack
Old Apr 11, 2008 | 10:21 AM
JLeeBB4's Avatar
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">coil pack</TD></TR></TABLE>
its a new distributor though.
I that the coil pack was in there? maybe im wrong.
Old Apr 11, 2008 | 10:34 AM
Not unless you have an internal coil distributor.
They are JDM dizzys that have that.
USDM dizzies are external. If you have a total of 5 wires coming off your dizzy its USDM. 4 wires is JDM.
Old Apr 11, 2008 | 07:59 PM
JLeeBB4's Avatar
I know i have a jdm dizzy but what could be causing the misfire?
Old Apr 11, 2008 | 08:42 PM
ludelover88's Avatar
i have the same problem but can't figure out what it is if you find out let me know
Old Apr 14, 2008 | 04:26 PM
preludeSRV's Avatar
Default Re: (ludelover88)
I had the infamous misfire codes and just swapped my engine I couldn't handle changing everything and having the same damn code come up
808DA
Mar 26, 2009 05:24 PM
aziaticvang
May 14, 2008 09:04 PM
Rob!
Jan 31, 2006 05:21 PM
itrdriver1071
May 14, 2005 08:18 AM
TwoPointZero
Mar 27, 2004 07:23 AM
