Could it be the distributor!
Well my car is have a bogging problem, and the cel is 71 which is a misfire on cylinder 1. so i was thinking and it couldnt be the spark plug wires and the spark plug cause i have changed it already. so all is left is the distributor right? and could the distributor cause the car to misfire there for leading to making the car bog on like every gear on low Rpm? (this is for a 96 Ek)
I'm having the same problem and couldn't figure out what's wrong with it. I've even change ngk plugs, wires, and rotor to see that was the issue but no luck. Yah...there's no cel either.
