Still having missing problems Help
Old May 14, 2005 | 07:45 AM
itrdriver1071's Avatar
Default Still having missing problems Help
I changed the o2 sensor and for about 2 weeks it ran fine... better gas mileage etc.
then today i get in my car this morning to take it to a detailer and it starts missing. im buying a distributor, wires and plugs see if that helps. if this has happened to anyone else with their itr please let me know what remmedies you have thanks
Old May 14, 2005 | 07:46 AM
Opie's Avatar
Any CEL?
If you're misfiring you will get a CEL. If your Distributor is crapping out you will get a CEL.
Old May 14, 2005 | 07:50 AM
Default Re: (opie)
yes i do have a cel it blinks then stays on but it has done this many times before and will pick and chose when it wants to misfire. does this still sound like the distributor?
Old May 14, 2005 | 07:54 AM
RTW DC2R's Avatar
check the CEL and see what it says. sounds like plugs, wires, cap/rotor would be a good place to start. its always good to replace that stuff anyway.
Old May 14, 2005 | 08:02 AM
Chris F's Avatar
Default Re: (RTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW &raquo;</TD></TR><TR><TD CLASS="quote">check the CEL and see what it says. sounds like plugs, wires, cap/rotor would be a good place to start. its always good to replace that stuff anyway.</TD></TR></TABLE>
For real...
Did you do that already? Was it a random misfire? If you can't get codes, just beat on it for a little while, it will eventually throw one. Definitely start replacing ignition system bits (coil, cap, rotor, wires, plugs).
My car was missing in boost when warm (not hot).... *shrug*
smaller gapped plugs may have helped. But a N/A ITR shouldn't miss unless your gaps were totally screwed up.
Chris F's Avatar
Default Re: Still having missing problems Help (itrdriver1071)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrdriver1071 &raquo;</TD></TR><TR><TD CLASS="quote">i get in my car this morning to take it to a detailer </TD></TR></TABLE>
Maybe your car is trying to tell you something.
Track caR &gt; Show caR
Old May 14, 2005 | 08:05 AM
Opie's Avatar
Here's a thread of mine from a while ago.
https://honda-tech.com/zerothread?id=1140963
Old May 14, 2005 | 08:12 AM
KayOs's Avatar
I had a misfire CEL recently .....
turned out to be a faulty spark plug wire.....
Old May 14, 2005 | 08:13 AM
Default Re: Still having missing problems Help (opie)
when it did this a couple weeks back it said that it was a random misfire on the computer scan and i did change the plugs and wires a while back (ngk's) and the wires i think are bosch but i did not change the cap and rotor
Old May 14, 2005 | 08:15 AM
KayOs's Avatar
DId you use OEM or aftermarket parts when you replaced the components ?
Old May 14, 2005 | 08:17 AM
Default Re: Still having missing problems Help (KayOs)
ngk plugs i think bosch wires and bosch o2 sensor
Old May 14, 2005 | 08:18 AM
KayOs's Avatar
Try changing the rotor and distributor cap (use OEM)
Mr. Bojangles
Apr 26, 2013 07:47 PM
fryman
Jan 13, 2011 03:44 PM
EJ8_Enthusiast
Jun 15, 2009 06:02 PM
92boostedgsr
Jun 1, 2009 05:55 AM
Tim2179
Feb 20, 2007 12:08 PM
