89 grade in rsx?
I tried search and found nothing. would it matter to run 89 grade gas in my rsx-s? I mean with the price of gas now it would help my wallet out a lot instead of the usual 93. the motor is stock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">Your ECU will dial back the timing with 89 or less. You'll lose power and mileage will probably go down.
Read your owners manual.</TD></TR></TABLE>
yep my friend tried it in his rsx-s and got less MPG than running the 93. so you end up spending the same or more.. plus you run the risk of making the knock senor to mess up and then your engine will drive with a knocking sound.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Desperado »</TD></TR><TR><TD CLASS="quote">I tried search and found nothing. would it matter to run 89 grade gas in my rsx-s? I mean with the price of gas now it would help my wallet out a lot instead of the usual 93. the motor is stock.
If you cant afford the gas buy a civic
From: Your mommas bed, that might be true too ..., So Cali, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCFIVER »</TD></TR><TR><TD CLASS="quote">
HAHAHA great !! I got a GSR and only 91, so RSX's use 93 not 91 ??? 93 is rare in cali
i only ask cause im thinking about getting one !
</TD></TR></TABLE>HAHAHA great !! I got a GSR and only 91, so RSX's use 93 not 91 ??? 93 is rare in cali
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evolution-93-Ex »</TD></TR><TR><TD CLASS="quote">
i only ask cause im thinking about getting one !</TD></TR></TABLE>
naw 91 is fine. i live in so.Cal too.
Ive been using 89 for the last 2 or 3 months and run it hard almost everyday and it runs like a champ with 100k+ miles. After seeing that 89 or less can dial back the timing i think ill just use 93 lol. Hope it can dial back up!
damn cheap *** ****'s! the difference between premium and 89 is like $.10 which is about $1-$1.20 more per full tank.
If you can't afford that, trade in your type S for a base or a civic.
lrcrx90
11
Jul 16, 2008 12:06 PM
Jonovision
Sep 30, 2005 06:48 AM
