Ordering a header! Need as many opinions as possible.
I am looking to order a header next week. Here's the choices : Comptech 4-2-1, DC 4-1 Stainless, or DC 4-2-1 Stainless. I don't want to modify the cat or to have anything welded. I just want to take it to the mechanic and say, "put this on". I know many people have JDM style headers and 2.5 cats, but i don't want to go that route. Any opinons and experiences would be helpful. Thanks.
Try and contact Racer X... He should still have two to choose from.. A mugen and spoon...
He's letting them go for cheap....
I have only seen the comptech and highly recommend it for your application.
As a side note I recommend you attempt the installation yourself since your car is not very old. I was able to swap mine out without much trouble.
toda, smsp, hytech...
of the three you mentioned, you might as well stay stock.....
Joo know, Spoon!!!Heres the test again to compare: http://www.automotiveperformanceengi...om/header.html
Good luck,
A.
If I am correct he wants to stick with stock cat and all these headers you guys are throwing at him are all 2.5".... If your staying with stock cat like I said... comptech and it's affordable.
Guest
Posts: n/a
Comptech or DC.. with the stock cat, it's pretty much equal..
You don't really need to upgrade your stock cat to make decent power..
Look my my dyno sheet from my other car.. B18C1 93 Civic Coupe
I know this pic sucks, but my scanner is on the fritz.. 177WHP 130lbs of torqe!
Less = More
Hope the pics show..
Less = More
I don't think the 2.5 JDM spec header and high flow cat will be much of a problem. They are "bolt-ons" and if you order the correct Carsound cat from SMSP, or the other board sponsors you should have no problems. I think the gains will be worth it. Car will breath much better..
Drinker
