WTB: Aftermarket front swaybar for 90 CRX Si
Hybrid - Swap
B Series
Detailed B Series Swap into 5th Gen Civic How-To
Identifying 1st and 2nd generation B16A
B16A Resource Site Full Swap Info
Vacuum diagram! B16 swap
B16 2nd O2 sensor
Rywire B16 Swap
The LS/VTEC Swap Page
LS 5th Gear Install guide! JDM B16 S1
DOHC ZC
(DOHC)ZC for Dummies
The DOHC ZC swap
D Series
Z6 Mini-Me Swap
Mini-me and Engine Theory
D15 OBD1 SOHC VTEC Mini-Me : Massive Write-up
DPFI-MPFI swap information
DX,STD (DPFI) -> Si,HX (MPFI) wiring
SOHC upgrades *REVISED* It's long and is a work in progress
Cool Free Tuning Software for PM6 Ecu's
D Series piston pics
OBD1 injector pin swap/removal-How-to
Compression Calculator
Do It Yourself
ECU Codes and trouble shooting
Axle Replacement Tutorial With PICS!
Removing steering rack(non-power steering)
Extended Shock Travel
Rebuilding your sunroof
Rear Positive Camber Washer Trick
OEM HID's into 9006 housing
KAAZ LSD Installation
Overboost Suspension and Bushing Installation
Hotrod Bushing Installation
Notes about JDM L3 "ZC tranny"
CRX WORLD Transmission Rebuild
How to Remove / Rebuild / Test CRX Alternators
How to Remove CRX / Civic Steering Wheel
How to Remove CRX Door Panel
How to Remove CRX Door Sill
CIVIC/CRX EURO SiR CLUSTER Wiring
HONDA DISTRIBUTOR REPAIR
Honda Radio Wire Harness
VTEC Explained
Real Time 4 Wheel Drive 4wd rt4wd
Differences in CRX's
ECU Identification
Ideas: Flow Velocity, Flow Capacity, Flow Quality
All Honda car stock weights
Honda Performance FAQ
US 1991 Honda CRX New Car Brochure
Modified by Tyson at 9:18 PM 1/28/2006
All_Motor_Rex
Apr 14, 2004 05:10 PM
integraracing91
Feb 11, 2004 07:15 PM
