help!!!!!! with turbo-smart dual stage boost controller
i am just really confuse on how to wire up the switch that changes over from low to high boost
on boost controller you have 2 wires a brown (ground) and a blue (positive) wire
now i have the kill switch that changes the boost from low-high
how do i wire up the kill-switch to the boost controller
i have searched and on there intructions they dont say much
thanks for the help
thanks for the help
The blue wire is run to the switch and then from the switch to a 12 volt fused power source. I would say a switched power source would be best (activated with the key in the "on" position in the ignition switch). The brown wire goes to a chassis ground.
so do i run the blue wire to the high boost switch?
then what about the low boost all it gets its power?
By activating the switch (power on) you switch the boost controller to the high boost setting. With the power off, the boost controller remains at the low boost setting.
so pretty much the low boost setting dosnt get any power...........
the only thing getting power is the blue wire that runs to the high boost switch
boostincoupe
Jan 7, 2005 01:17 PM
aturbosmart, boost, civic, controler, controller, dual, dualstage, honda, hondatech, install, review, stage, switch, turbosmart, wire
