gas smell
Old Apr 4, 2008 | 04:29 PM
1993-eg1's Avatar
Default gas smell
I have a 93 del sol si with the d16z6 it has 196k on it with a air intack and exaust as spring is coming I am geting a bit of a gess smell when i start it that goes away quickly after I ran a compression test on my engine and had around 200 on all.
Old Apr 4, 2008 | 04:32 PM
slambedcivic's Avatar
Default Re: gas smell (1993-eg1)
leaky fuel injector seal?
Old Apr 4, 2008 | 04:37 PM
1993-eg1's Avatar
Default Re: gas smell (slambedcivic)
What would I look for?
Old Apr 4, 2008 | 04:38 PM
well i would start looking for fuel.
Old Apr 4, 2008 | 04:47 PM
1993-eg1's Avatar
will try in the morning i forgot to mention that when it is cold it ideals like 2000 rpm and when it is warm it might ideal 500 rpm and i have cleaned the vaive under the tb
Old Apr 4, 2008 | 04:49 PM
when you cleaned it, did you screw the plunger all of the way back in?
Old Apr 4, 2008 | 04:58 PM
1993-eg1's Avatar
6 turns that same as it was when i took it out i had 2 more turns till tight.
Old Apr 4, 2008 | 05:14 PM
1993-eg1's Avatar
Does what I did sound right?
Old Apr 5, 2008 | 11:57 AM
sure. i screw mine all of the way in. it simply prevents your idle from surging all over the place. did you find the gas leak?
Old Apr 5, 2008 | 04:16 PM
1993-eg1's Avatar
on and when i started it this morning there was no gas smell but it was back in the 30's so be it when it hits 50's i am going to go out and look at it to see but i do not no y temp would mack a daffiness but i guess we will see
Old Apr 5, 2008 | 05:16 PM
torontoefsedan's Avatar
well if there no change in gas milage, id say youre fine. its not a big enough leak then to pose a problem. and ya your idles fine
Shanasman12
Apr 9, 2014 08:45 PM
MR_FIX_IT
Apr 7, 2007 08:35 PM
Mr_Moos
Feb 27, 2007 05:33 PM
mongoliandonuts
Sep 22, 2004 06:52 PM
gear
Nov 29, 2003 12:36 AM
