92 CX Hatch Low Fuel warning light adding
Old Apr 4, 2008 | 11:45 AM
likwidchz's Avatar
Default 92 CX Hatch Low Fuel warning light adding
Hey guys,
So I compared the EG hatch with the EK and it appears that the fuel sender unit is identical in both cars, however the stock EG CX does not have the low fuel warning light.
I swapped in the 99 civic cluster into my EG since it looks neat-er anyway... The low fuel light dosent seem to be functioning at all as when there is low fuel that pin that comes off the fuel sender unit simply goes from "NC" not connected to grounded, this is how all the lights work on the cluster is by activating grounds to enable and disable lights on the dash..
anyway its not working, the question is, Has anyone done this before?
--Aaron
Thanks.
Old Apr 4, 2008 | 02:38 PM
MasterShake's Avatar
i didnt know "EGs" had low gas lights
Old Apr 4, 2008 | 04:14 PM
1988_96hb's Avatar
Default Re: (MasterShake)
my "EG" doesnt and i used to hate it.
Modified by 1988_96hb at 10:10 PM 4/4/2008
Old Apr 4, 2008 | 07:04 PM
likwidchz's Avatar
yes, your both right, EG's do not have low gas lights, although
comparing the EK to the EG service manual they both use the same fuel sender part numbers, and after further inspection it looks like theres just a unused wire and im going to take a stab at it, but im guessing that the low fuel warning light simply goes "ground" once you reach a certian level of fuel in the tank, IE able to wire that back up to a dash light...
sooooo looking in my tank after taking the top off the fuel tank under the rear seat appears as if its not working as there's about1/4th of an inch of fuel left in the tank. so guessin its borked somehow...
my 3 cents.
Old Apr 4, 2008 | 08:59 PM
why dont you just get gas when it gets low
Old Apr 5, 2008 | 07:51 AM
likwidchz's Avatar
heh
Old Apr 5, 2008 | 10:00 AM
badboyr66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterShake &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just get gas when it gets low</TD></TR></TABLE>
hmm what he said
Custard
May 9, 2017 04:18 PM
jmaze
Oct 24, 2007 07:31 PM
ME SO FST
Apr 25, 2007 07:45 AM
Manolo
13
Oct 3, 2005 08:31 AM
KayOs
42
Feb 3, 2003 06:41 PM
