ecu making my car have idle like vacuum leak
Old Apr 4, 2008 | 10:28 AM
turbojdmhatch's Avatar
Default ecu making my car have idle like vacuum leak
my ecu(p06) makes my engine idle like it has a vacuum leak. Meaning when the engine is warm and should idle at under 1000 rpms the idle is eratic just like a vacuum leak. I had my friends chipped p28 in and the idle went back to normal and his winter beater had the same idle with my ecu.Has this happened to someone else or what? just looking for some advice in what can be causing this problem since when i have his ecu in my car the idle has not acted like it has a vacuum leak. Really i just hate pulling up to a stop light and having people look at me like im revving my motor at them and looking like an idiot.
Old Apr 4, 2008 | 10:37 AM
ballinboosi's Avatar
Default Re: ecu making my car have idle like vacuum leak (turbojdmhatch)
actually i just changed the hg in my new 94 hatch and it did that when I first started it back up. So I checked a few things (vacum, sensors and what not) and then pulled the ECU fuse under the hood and started it up and it worked fine. Still not sure why but maybe you can try that and hope it works.
Old Apr 4, 2008 | 10:40 AM
Relic1's Avatar
is either ECU chipped?
Default Re: ecu making my car have idle like vacuum leak (ballinboosi)
yea my head gasket got changed about 2 months before i turboed my car plus i have arp headstuds its just the ecu since once i swapped mine out for my buddies last night he started his car and it idled like a vacuum leak even tho it doesnt have one and mine didnt at all which i must say is very nice. i just dont want to have to go out and get a new one since i got the shaft with my job and havent found a new job yet and im strugglin for cash.
Old Apr 4, 2008 | 10:43 AM
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">is either ECU chipped?</TD></TR></TABLE>
no i took the P06 with the idle problem apart and found no chip in it. The car was turbo before i bought it and when the car was sold they took the turbo off and idk if it had a basemap on it or anything but there isnt a chip IMO the ecu is FUBAR
Old Apr 4, 2008 | 11:00 AM
Default Re: (turbojdmhatch)
that's what is sounds like....you should be able to get a cheap one off ebay or a junkyard....
Old Apr 9, 2008 | 07:58 AM
bigizsosexy's Avatar
Default Re: (ballinboosi)
I have a similar problem, chip and ecu wiring is making my car idle and run was too rich. Tell me if you solved yours
Old Apr 14, 2008 | 08:23 PM
2wheelhunter's Avatar
Default Re: (bigizsosexy)
yea i solved mine buy getting the ecu outta my buddies car before he sold it....problem fixed
Old Apr 17, 2008 | 10:45 AM
Default Re: (2wheelhunter)
Ight cool. I am in the process of changing my ecu old one fried. so hopefully this works
RinzEG6
Nov 24, 2014 12:02 PM
MonkeyMagic
May 4, 2008 02:30 PM
freddy_hung
Acura TL, RL & ZDX
Nov 25, 2005 03:07 PM
toyzbus
Mar 15, 2005 11:55 AM
LSpimpTEC
Apr 28, 2003 11:29 PM
