H22 Vacuum Line Issues
Hey, i have some open vacuum lines, can anyone help?
Here's how the whole thing looks....
Where does the line coming from here go?
this seems to work fine....
Saw a thread with a vacuum line diagram that showed that this was alright.....
HELP!!!
HELP!!!
irc, the first is for the egr system that goes on the prelude's driver side fender area. the second one above the tb went to this little sytem underneath the prelude's intake box; supposedly it quieted down the engine noise when it hit a certain rpm. Im sure you can plug both of those and you'll be fine, depending on what ecu you're using
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bassysingh »</TD></TR><TR><TD CLASS="quote">Hey, i have some open vacuum lines, can anyone help?
this one goes to the stock Prelude Cruise control...just cap it.
ok, so basically i need to get the cvc and the egr control solenoid valve and route the vacuum lines to the egr valve. great. question now is if this is necessary if i don't have the egr plugged up? and if not then what do i do about the open vacuum?
Greyout
28
Mar 8, 2004 02:16 PM
