Replacing slip fittings w/threaded
Old Aug 7, 2002 | 11:57 AM
xci_ed6's Avatar
Default Replacing slip fittings w/threaded
I tapped all the holes on my intake manifold to accept threaded fittings so my vac lines don't blow off. How do I attatch to the MAP sensor (and stuff) though?
-Dustin
Old Aug 7, 2002 | 03:00 PM
DJ0820's Avatar
Default Re: Replacing slip fittings w/threaded (Autocratic_1st_Gen)
You have problems with your vacuum lines blowing off? And why would a vacuum line blow off? There would be no positive pressure in it because it is a vacuum line.
Later,
Derek
Old Aug 7, 2002 | 03:04 PM
filetofit
Guest
Posts: n/a
Default Re: Replacing slip fittings w/threaded (DJ0820)
Later,
Derek
Uh, I hope you're kidding.
Old Aug 7, 2002 | 03:05 PM
Smashback's Avatar
for you ... do you think that positive pressure is so smart that it will not travel thru vacuum lines because it knows they are called vacuum lines?
As for the original question, I'm not exactly sure what you did....pics?
Old Aug 7, 2002 | 03:13 PM
BROOD's Avatar
Default Re: Replacing slip fittings w/threaded (mplex2000)
Yea, some photos would help inspire some suggestions.
Old Aug 7, 2002 | 03:36 PM
technine's Avatar
Later,
Derek
Hide in shame
Old Aug 9, 2002 | 06:51 AM
xci_ed6's Avatar
Default Re: Replacing slip fittings w/threaded (technine)
Derek is a moron.
I drilled out the little copper tubes that the vac line slipped on and tapped the hole. Then I threaded in a compression fitting and attached the vac line. But I don't want to drill into the MAP sensor body-so how do I put a compression fitting on it?
-Dustin
Old Aug 9, 2002 | 02:42 PM
qwkteg125's Avatar
did you previously try zipties around the vacuum lines to secure them to the factory slip fittings? i don't know of anyone who has done that & still had a problem of lines blowing off...
Old Aug 9, 2002 | 04:55 PM
00TurboEX's Avatar
Default Re: Replacing slip fittings w/threaded (qwkteg125)
thats what i do, may be kinda ghetto, but i works and doesnt look THAT bad.
david
Old Aug 9, 2002 | 05:21 PM
Jared's Avatar
Default Re: Replacing slip fittings w/threaded (00TurboEX)
it is kind of ghetto but i use zip ties for my vacuum lines and they work great.
Old Aug 9, 2002 | 08:28 PM
inspyral's Avatar
Default Re: Replacing slip fittings w/threaded (Jared)
zip ties
Old Aug 9, 2002 | 08:31 PM
VaporTrail's Avatar
New User
try some plastic weld on the nipple, and create a bead around the end. Then zip tie it, it won't blow off
Old Aug 10, 2002 | 05:35 PM
xci_ed6's Avatar
Default Re: Replacing slip fittings w/threaded (VaporTrail)
My way looks way more cooler though. Damn, guess I'll have to think for myself.
-Dustin
crazyimport
May 22, 2006 06:18 PM
EM1specR
Mar 15, 2005 01:17 PM
B18 CYA
Jul 16, 2004 11:20 PM
JDubya
Apr 12, 2004 07:48 AM
