Does GE Sandwhich adapter have two ports?
My full race kit comes with a 'Y' to run my stock oil pressure and oil feed line, but I also have a oil temperature and oil pressure gauge I need to run. How would I hook up these gauges to the sandwhich adapter?
Your oil temp sensor goes in the oil pan, so you're only another T from adding the pressure sensor. I would put it up on the firewall so it's easy to get to and you don't have 382 things off the block fitting.
It's a -8AN o-ring port, but it's also got an AN flare as well. You can use either adapter.
I would run the turbo oil feed line from the sandwich plate.
Use a -8AN flare to -3 or -4AN flare adapter on the larget port to feed the turbo.
Use a 1/8" NPT to -4AN flare adapter and some -4AN hose to feed the oil pressure gauge.
Place the oil temperature gauge in the oil pan.
The stock oil pressure sensor can stay in the stock location.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">It's a -8AN o-ring port, but it's also got an AN flare as well. You can use either adapter.
The stock oil pressure sensor can stay in the stock location.</TD></TR></TABLE>
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
