poor mans type r compression test
Old Mar 25, 2008 | 05:25 PM
carlosp38's Avatar
Default poor mans type r compression test
we ran a compression test on my buddys poor mans type r.. he has a jdm gsr bottom end with a usdm b16a2 head... his compression came up to 130 psi all the way around... is that normall? that seems to low for me what do you guys think could be wrong? thanks
Old Mar 25, 2008 | 05:48 PM
crazyguy's Avatar
Default Re: poor mans type r compression test (carlosp38)
thats way too low. the normal compression should be
9.5:1~11:1 compression: 210-275 psi per cylinder
Old Mar 26, 2008 | 03:11 AM
carlosp38's Avatar
yea.. but y would it be so low.. i dont understand.. and the car starts up fine and everything..
Old Mar 26, 2008 | 08:11 AM
Blk00EJ8's Avatar
Default Re: (carlosp38)
Maybe you should redo the comp test. Did you do it with the engine warm or cold?
Old Mar 26, 2008 | 03:31 PM
carlosp38's Avatar
i did it when it was warm..y? it makes a diffrence? when is it best ???
Old Mar 26, 2008 | 03:43 PM
da6er's Avatar
i had ctr's pistons and my psi was 245 all the way around. that sounds way to low to me.
Old Mar 26, 2008 | 04:05 PM
FastLife617's Avatar
Default Re: (da6er)
yeah dude those numbers are low
Old Mar 26, 2008 | 04:31 PM
carlosp38's Avatar
yea those numbers are too low..i had an american gsr and the compression on each piston was 230..and i sold that motor and built this one..i saved the head .004 and then stock type r head gasket and 99 b16head..i dont know what the problem is..it runs stronger than my gsr and like a buety..
Old Mar 30, 2008 | 06:31 PM
dtownrex's Avatar
need to do the test when car is at normal operating temerature
88 civic
Apr 5, 2009 03:21 PM
Hondizzle!
Sep 13, 2005 09:13 AM
Nisif
Apr 12, 2005 09:13 AM
builtprelude
Jan 22, 2004 10:49 PM
DSayavan
Apr 1, 2003 01:07 PM
