Overheating question
Old Mar 20, 2008 | 05:50 AM
eric416's Avatar
Default Overheating question
My h22 has been getting hot lately but only during idle. The temp is fine when i am driving. I only have one fan because i got rid of the other one when i removed the a/c. I was told it was alright. I don't think that has anything to do with it because it only had 1 fan for over a year and the problem just started happening now. What else would be causing it to overheat. I'm doing a coolant flush and replacing the thermostat today.
Old Mar 20, 2008 | 06:12 AM
vlang29's Avatar
Default Re: Overheating question (eric416)
sounds like fan relay... is your fan coming on?
Old Mar 20, 2008 | 04:12 PM
eric416's Avatar
Default Re: Overheating question (vlang29)
The fan does turn on sometimes but today when i went to go change the coolant i saw that it was kind of low and also that my radiator looks like this. It is 5 years old. Time for a new one?
Old Mar 20, 2008 | 05:36 PM
slamdlude's Avatar
Yeah, I would say it is probably time for a new radiator. That thing looks like crap! No wonder you're overheating!
Old Mar 21, 2008 | 08:52 AM
smo0th's Avatar
Default Re: Overheating question (slamdlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slamdlude &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I would say it is probably time for a new radiator. That thing looks like crap! No wonder you're overheating! </TD></TR></TABLE> x2 Good luck
Old Mar 21, 2008 | 09:02 AM
JJMSmith1's Avatar
I just picked up a C&R radiator from slowmotionmotorsports.com $275 shipped. Check it out
Old Oct 22, 2009 | 01:54 PM
canadianr's Avatar
New User
is there a how to for bleeding the coolant for the h22 engine? I mostly work on nissans and know where to bleed the air from the coolant runs, but am not sure on the honda stuff.
does anybody know a link for where to bleed the coolant on the h22?
Old Oct 23, 2009 | 06:48 PM
SkylineKin's Avatar
its on the thermostat housing, fill up the coolant with the bleeder valve open until it flow out, shut it, then start the car and bleed the air out, make sure your heat is on full blast during the whole process.
Old Oct 23, 2009 | 07:36 PM
nus_dogg's Avatar
Yup, the bleed screw on the Thermostat housing. You can also remove the radiator cap and let the car idle which will disperse air bubbles.
Old Oct 23, 2009 | 08:07 PM
minilogoguy18's Avatar
Car doesn't need to be running, just pour coolant til a steady stream comes out of the bleeder screw.
Old Oct 23, 2009 | 09:52 PM
pkolaboy's Avatar
I would replace your fan also and check your wiring to the fan and such, wires may be corroded...also look for cracked or frayed coolant lines...
dth0ng69
Jan 28, 2009 06:19 AM
eric416
Jun 11, 2008 08:03 PM
mackoy20
12
Jan 27, 2008 10:38 PM
Kalokohan
10
Sep 28, 2006 10:09 AM
RexB16
15
Jul 25, 2004 07:54 PM
