WILL precision sc 34 turbo .63ar bolt on my drag b series manifold
Old Mar 19, 2008 | 02:31 PM
Eklsv-t's Avatar
Default WILL precision sc 34 turbo .63ar bolt on my drag b series manifold
Im about to pick up precision sc34 turbo for my gsr. Will it fit on my B series Drag manifold and drag 5 bolt downpipe? Is this good turbo for 7psi 300whp?
Old Mar 19, 2008 | 02:43 PM
Eklsv-t's Avatar
Default Re: WILL precision sc 34 turbo .63ar bolt on my drag b series manifold (Eklsv-t)
I WANT to place turbo on passenger side close to block where my old turbonetics sat
Old Mar 19, 2008 | 02:47 PM
TheShodan's Avatar
Moderator
if you got the 5 bolt SVO flanged turbo from precision, it will fit, but you will have to notch the block..
Old Mar 19, 2008 | 02:49 PM
Schister66's Avatar
Man U FTW
I'm not sure on fitment (although TheShodan covered it), but as for the power goals, you may have to run a little more than 7psi to hit your goal. Dont worry about the psi required to make 300whp unless you're staying within the confines of the stock MAP sensor. PSI doesn't mean anything...
Old Mar 19, 2008 | 02:55 PM
Eklsv-t's Avatar
Default Re: (Schister66)
yes its the 5 bolt exhaust housing precision
Old Mar 19, 2008 | 03:12 PM
95dc2teg's Avatar
Default Re: (Eklsv-t)
yes it will fit but as someone already said you will most likely have to notch the block. On my gsr with my precision sc34 and rev hard manifold, i had 306whp and 210tq with 12lbs.
Old Mar 19, 2008 | 03:34 PM
Eklsv-t's Avatar
Default Re: (95dc2teg)
Did you have to notch the block on your gsr, by how much? Im only boosting 7psi and plan to make 250whp
Old Mar 19, 2008 | 03:59 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eklsv-t &raquo;</TD></TR><TR><TD CLASS="quote">Did you have to notch the block on your gsr, by how much? Im only boosting 7psi and plan to make 250whp</TD></TR></TABLE>
With a Drag Manifold, and an "E" cover that precision uses, yes. You will always have to notch the block.. I'm gonna say this again.. you will always notch the block with that combination..
Old Mar 19, 2008 | 04:53 PM
95dc2teg's Avatar
yes i did
u n v kenny
Jun 7, 2007 07:44 AM
civicb18Tkid
Mar 16, 2007 11:13 AM
tegasaurus
Jul 24, 2003 03:48 AM
Full-Race Geoff
Jun 3, 2003 04:41 PM
chris@cfranklins
Jan 1, 2003 04:35 PM
