My F23/H22 87x97mm H2B Build
Old Mar 17, 2008 | 07:26 AM
jdm_ef9's Avatar
Default My F23/H22 87x97mm H2B Build
This is my little write-up of my F23/H22 build. I am building this motor for my 91' Civic HB. This car is NOT my daily driver, it is used merely for drag racing as well as some street action.
I will try and keep the thread updated as much as possible. Here's the breakdown:
CAR: 1991 Civic DX HB
ENGINE: F23A bottom end / H22A Head
TRANNY: JDM B16A S1
I am using 87mm K20 pistons and the 97mm crank which will yield 2306cc.
I am going to begin the building phase soon, I will be setting the motor in the car for mock-up before the block goes to my machinist. I will provide further information and pics later.
Patiently awaiting...
Modified by jdm_ef9 at 7:36 AM 3/18/2008
Old Mar 17, 2008 | 08:50 AM
2fastGSR's Avatar
King of the One Liners
Default Re: My F23/H22 87x97mm H2B Build (jdm_ef9)
Nice planned build . . .
Old Mar 17, 2008 | 09:13 AM
jdm_ef9's Avatar
Default Re: My F23/H22 87x97mm H2B Build (2fastGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fastGSR &raquo;</TD></TR><TR><TD CLASS="quote">Nice planned build . . . </TD></TR></TABLE>
Thanks... always a good thing to plan and do your homework when building something to this extent.
Old Mar 18, 2008 | 03:41 AM
jdm_ef9's Avatar
Got a complete F23A longblock for $100. Here is the block(before bead blasting):
MMMMM.... 55mm mains:
Picked up a complete H22A4 longblock for $200 - just had a bad crank. Here is the head:
Old Mar 18, 2008 | 10:06 AM
Shadowz7429's Avatar
should be good when done dude!
Old Mar 18, 2008 | 02:00 PM
2fast4u831's Avatar
I'm really 2slow
Default Re: (Shadowz7429)
nice!!
Old Mar 18, 2008 | 02:45 PM
88ED8's Avatar
Default Re: (2fast4u831)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2fast4u831 &raquo;</TD></TR><TR><TD CLASS="quote">nice!! </TD></TR></TABLE>
x2
Old Mar 18, 2008 | 03:03 PM
.Hatches.'s Avatar
excellent choice. was seroiusly thinking going this route.
Old Mar 18, 2008 | 05:32 PM
bjones's Avatar
Default Re: (.Hatches.)
i like what i see so far. subscribed!!
Old Mar 18, 2008 | 11:43 PM
AdamB18C1EK's Avatar
Default Re: (bjones)
the shell is nice as hell from what i can see. really clean engine bay at least. what are your plans for cams
Old Mar 19, 2008 | 03:21 AM
jdm_ef9's Avatar
Default Re: (AdamB18C1EK)
thanks for all of the comment guys!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote">what are your plans for cams</TD></TR></TABLE>
i will be running approx 12.5:1cr and pro3 cams.
some of my parts are staring to arrive... i will get pics up soon!
also, the engine is getting mocked up tonight and i plan to drop it in to see what the clearance is like. stay tuned!
Old Mar 19, 2008 | 04:07 AM
Jay-DM's Avatar
Default Re: (jdm_ef9)
was really close to doing the same setup but changed my mind last minute u gonna do anything else to the block. GL
Old Mar 19, 2008 | 08:00 AM
Lubo_25's Avatar
is it safe for a piston travelling in a clockwise direction to be put into a motor working in the opposite direction?? custom cp pistons only ran me 600$ for an H22(89mm, 12.5 static cr. for 54 cc chambers)
definitely subscribed for this build up keep us posted comrade
Old Mar 19, 2008 | 01:32 PM
jdm_ef9's Avatar
Default Re: My F23/H22 87x97mm H2B Build (Lubo_25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">is it safe for a piston travelling in a clockwise direction to be put into a motor working in the opposite direction?? custom cp pistons only ran me 600$ for an H22(89mm, 12.5 static cr. for 54 cc chambers)
definitely subscribed for this build up keep us posted comrade </TD></TR></TABLE>
safe.... i would say yes.
oem reliable.... not so much but you cant really expect that when building something like this.
i worked with jeff from blueprint and got a set of trick wisecos.
Old Mar 19, 2008 | 05:53 PM
accordm3's Avatar
Nice build. I am going to emulate this setup when if you put down over 250
Old Mar 20, 2008 | 04:20 AM
jdm_ef9's Avatar
Default Re: My F23/H22 87x97mm H2B Build (accordm3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 &raquo;</TD></TR><TR><TD CLASS="quote">Nice build. I am going to emulate this setup when if you put down over 250 </TD></TR></TABLE>
Thanks
Well, it wasnt easy but the engine is in(temporarily)! There are a few mods to the chassis I have to make before it goes in for good. I snapped a few teaser pics:
Hood clearance
Old Mar 20, 2008 | 05:21 AM
Lubo_25's Avatar
time to get the grinder and zip wheels out...lol that thing will look like a beast in that chassis
Old Mar 20, 2008 | 08:36 AM
jdm_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">time to get the grinder and zip wheels out...lol that thing will look like a beast in that chassis</TD></TR></TABLE>
Old Mar 20, 2008 | 10:57 AM
88ED8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lubo_25 &raquo;</TD></TR><TR><TD CLASS="quote">that thing will look like a beast in that chassis</TD></TR></TABLE>
yes it will
Old Mar 20, 2008 | 11:30 AM
Lubo_25's Avatar
hahaha...
Old Mar 20, 2008 | 06:22 PM
jdm_ef9's Avatar
block/head are off to the machine shop in the morning!
Old Mar 20, 2008 | 07:30 PM
Gold DA9's Avatar
Im gonna be following this build.
Old Mar 21, 2008 | 05:18 AM
BlkChryKord's Avatar
Interested in what work was require to run the K pistons in the F23.
Old Mar 21, 2008 | 03:29 PM
jdm_ef9's Avatar
Default Re: (BlkChryKord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkChryKord &raquo;</TD></TR><TR><TD CLASS="quote">Interested in what work was require to run the K pistons in the F23.</TD></TR></TABLE>
Really all depends on what you are doing... With the K20 and F23 having the same compression height it makes for a fairly simple swap. If you plan on running a high cr or high lift cams then a little more work is required with the pistons.
Old Mar 21, 2008 | 04:12 PM
bjones's Avatar
have you made a choice on a header yet?
