problem
Old Mar 15, 2008 | 04:11 PM
spyderpaint88's Avatar
Default problem
ok so i am having problems shifting into first and seccond gears people say it is my clutch i have no idea any ideas and any prices?
Old Mar 15, 2008 | 04:30 PM
charichard's Avatar
Default Re: problem (spyderpaint88)
your question is a little vauge. but it could be anything really. Maybe a bad tranny, maybe a bad synchro in your first or second gear. It might be the clutch, but have you checked the slave and master cylinder for the clutch. Bleed the system maybe? Or check to see if your clutch fluid is low.
But if it is your clutch then a simple clutch job with an oem spec clutch from range from 4-8 hundred dollars depending on who you take your car too and what they do excatly. IE flywheel resurface is extra and so is flushing the tranny.
Old Mar 15, 2008 | 04:38 PM
spray_bombed's Avatar
1st gear isn't synchronized so scratch that
sheBangZ
Oct 16, 2007 05:04 PM
BlackLudeSR
Jul 4, 2007 04:51 PM
Z7
11
Feb 9, 2006 06:53 PM
scrubachu
Jul 11, 2005 08:49 AM
GapxGuy
May 11, 2003 08:20 PM
