Problems with obd1 jdm b16 in my 96ek hatch
Old Mar 14, 2008 | 09:21 PM
bigwally9876's Avatar
Default Problems with obd1 jdm b16 in my 96ek hatch
Ok so ive done my swap now, i followed Katmans write up and now the car runs but its running very rough and when i give it to much gas it bogs and then dies
Anyone have any idea what could cause this?
obd1 jdm b16 into my 96ek hatch.
Old Mar 15, 2008 | 01:19 PM
PwRLiMeH22's Avatar
Default Re: Problems with obd1 jdm b16 in my 96ek hatch (bigwally9876)
Is it wired right? Did you check for consistency from connector pin to ecu pin on each wire?? I'm working on the same swap, mines all wired up correct I'm just waiting on the tranny torque bracket... Does your gauge cluster work?? That's what I'm wondering about mine....
Old Mar 16, 2008 | 09:16 AM
well i used my sohc harness and am using a conversion harness and running a jdm p30 obd1 ecu, all the wiring seems fine, ive gone over the wiring a few times
Old Mar 16, 2008 | 10:01 AM
PwRLiMeH22's Avatar
Default Re: (bigwally9876)
Sounds like either MAP or TPS...
Old Mar 16, 2008 | 04:11 PM
egcoupeSI's Avatar
hey I'm having the same problem! Ive replaced the TPS and MAP sensors, but still having the same problem!! help!
Old Mar 16, 2008 | 08:58 PM
Default Re: Problems with obd1 jdm b16 in my 96ek hatch (egcoupeSI)
motor seems to be running fine, it doesnt shake or anything when running its just not idleing right, sounds very rough. When i unplug the the map sensor or the iacv it sounds diff, like worst so i figure that they are working correctly.... Im getting fustraded, i really wanted to get my car done and finished for a local show here in houston.....doesnt look like its gonna happen
Old Mar 17, 2008 | 05:14 PM
PwRLiMeH22's Avatar
Did you change all of the connectors on the dizzy and on the alternator? I just wired mine and it was A LOT of moving pins, all of the wire colors were different from obd2 to obd1 so I had to get diagrams for both.... You wired the knock sensor right? And it's going to the correct pin? I would double check the o2 sensor wiring as well, it kind of sounds like something there. I will be dropping mine in tomorrow, so I will let you know if this happens to me...
Old Mar 17, 2008 | 09:13 PM
aznej2's Avatar
Default Re: (PwRLiMeH22)
u tried switching the map and tps sensor plugs around? they both look identical and this is a common error
Old Mar 18, 2008 | 05:06 AM
Default Re: (aznej2)
you sir are correct, figured it out last night.... i had already tried switching the plugs before but i did not let the ecu reset. Lastnight i swapped the tps and map sensors and the disconected my batt for a few minutes.....after i connected it all again she turned on like a champ with no problems
Old Mar 19, 2008 | 07:09 PM
PwRLiMeH22's Avatar
Ok got mine swapped last night, it starts perfectly fine. Runs awesome for a 3-7 seconds , then dies. The more I cycle the key (to build fuel pressure) the longer it will idle. If I touch the gas at all it dies instantly. I know everything is wired right. I tried swapping the MAP and TPS but haven't tried resetting the ECU in between. It just sounds like it runs out of gas. Checked fuel pump with a test light and it's staying on until after the car stalls. Can't be injectors because it idles as smooth as can be (during its 5 seconds of glory). BTW my swap is a Obd1 B16a in a 99 DX hb..... Any suggestions??
Old Mar 21, 2008 | 02:16 PM
aznej2's Avatar
ok reading ur previous post u repined the the alternator and dizzy? first off i woulda just got an obd2 dizzy, alternator, and injectors to prevent any wrong wiring... have u tried resetting ur ecu yet wit switching the plugs? also have u checked the tps voltage at idle and WOT?
Old Mar 21, 2008 | 02:24 PM
aznej2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwally9876 &raquo;</TD></TR><TR><TD CLASS="quote">you sir are correct, figured it out last night.... i had already tried switching the plugs before but i did not let the ecu reset. Lastnight i swapped the tps and map sensors and the disconected my batt for a few minutes.....after i connected it all again she turned on like a champ with no problems </TD></TR></TABLE> glad ur car is running
Old Mar 22, 2008 | 05:11 AM
PwRLiMeH22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznej2 &raquo;</TD></TR><TR><TD CLASS="quote">ok reading ur previous post u repined the the alternator and dizzy? first off i woulda just got an obd2 dizzy, alternator, and injectors to prevent any wrong wiring... have u tried resetting ur ecu yet wit switching the plugs? also have u checked the tps voltage at idle and WOT?</TD></TR></TABLE>
Yeah I repinned the ecu on the alternator and dizzy. Wiring is all good for all of that, I tested continuity from connector the the right pin on the ecu (after the jumper harness). I did that for all connectors. I'm thinking that the ground and the load for the TPS might be backwards so I will check that tomorrow. Do you think it could be the fuel pump? I can hear it when I turn the get to Ignition and the more I cycle the key to ignition to build up fuel pressure the longer it will run. I haven't worked on it in a couple days, I'm kind of taking a break to get a fresh head on it so I haven't tried switching the plugs yet. But I will also check the voltage on the TPS and make sure it's all good. If you think of anything else, let me know.
Thanks!
Old Mar 24, 2008 | 05:44 PM
PwRLiMeH22's Avatar
MAP sensor... Pulled it, reset ecu and it idles. Rewired it and it will run with it plugged in but it's still not right. Ordering one tomorrow and that should be it! Thanks.
Old Mar 24, 2008 | 08:50 PM
damnraz's Avatar
lmao same thing happened to me when I did my swap, I was thinking for hours looking over my wiring and found that my tps and map plugs were the same, swap'd them around and it brought a smile to my face when i fired it up.
B Dap
Aug 13, 2010 09:34 AM
EJ2_ROB
Jul 16, 2010 11:48 AM
EF Owner
10
Nov 22, 2008 02:23 PM
remco
Oct 4, 2008 12:25 AM
zCivic
10
Mar 27, 2006 06:59 PM
