DIES WHILE IDLING
Old Mar 14, 2008 | 09:11 AM
stevew84's Avatar
Banned
Default DIES WHILE IDLING
i have a 97 ek with gsr vtec swap. i fire it up and leave it in neutral and take my foot off the clutch and immediately dies. its not dying from an electronic drain, but rather not high enough rpm's to keep it going. i gotta let it "warm up". this is very annoying since i just got the car bout 2 weeks ago. i heard about cleaning out the IACV but im not too sure what the process would be. also gotta adjust tension on throttle cable and in another thread someone was talking about the timing getting thrown off. could that be a problem? i should check my cam gears to see if they're alligned.
thanks for the help
steve
Old Mar 14, 2008 | 09:50 AM
darkblackH2B's Avatar
Default Re: DIES WHILE IDLING (stevew84)
try adjusting your idle. there should be a screw on the throttle body.
Old Mar 14, 2008 | 10:17 AM
CivicPride97's Avatar
Default Re: DIES WHILE IDLING (darkblackH2B)
same problem with mine and i adjusted the idle by moving around the idle screw and also the distributor. there are 3 14m bolts dont take them off just loosen them a bit and try moving it to see if idle gets better....
Old Mar 14, 2008 | 10:26 AM
stevew84's Avatar
Banned
yea the distributor idea would work my smog dude did it to my ef and now it idles smoother. it adjustes the timing position. i will try that on the ek i didnt even think of that.
MastaFlyMason
May 5, 2013 07:24 AM
raidacaipo
14
Jul 1, 2009 01:08 PM
b16a3delsol
Aug 15, 2007 09:29 AM
SwappedLSHatch
Apr 6, 2006 04:33 PM
TheIntegraGuy
Dec 28, 2002 06:49 PM
