idle problem
idle problem
Im having an idle problem on my b16. It sits around 1100 at the lowest but is usually around like 1400. I cleaned my IACV and my FITV. What else could be the cause of that? I also have checked for vaccum leaks and dont have any. Thanks
Re: idle problem (lsdelsol)
did it ever idle fine? if not, first make sure your throtle body isnt getting stuck open just a lil, or theres a screw on the face of the throtle body that also controls the idle... you can also check your timing... if its not anything like that you might have to check your intake manifold and throtle body... hope this helps...
Re: idle problem (se_hatchback)
i just this week finished the swap. Is it the big screw on the front of the throttle body. The high idle just bugs me or otherwise i wouldnt worry about it. thanks
mad21kid
02-18-2008 12:52 PM
