Question about hi and low beams on my 95 civic!!!!
Old Mar 11, 2008 | 12:10 AM
mikes 95 integra's Avatar
Default Question about hi and low beams on my 95 civic!!!!
Well guys i was changing the plugs for my headlights cause they were old and for some reason my lights work but when i turn my hi beams on the light that i changed the wiring on turs off.then when i turn the hi beams off it turns back on.I even put the old plug back on and it still does the same thing.
Old Mar 11, 2008 | 12:12 AM
HONDACIVC93's Avatar
what? you changed the wiring on what? your low beams are SUPPOSED to turn off when your high beams come on. what exactly did you change and why?
Old Mar 11, 2008 | 12:21 AM
Default Re: (HONDACIVC93)
I changed the headlight plugs the ones with the three prongs because they were rusted and old.i only changed one of the lights.The side that i changed turns of while the other side stays on only when i hit the hi beam switch.so only one side of the hi beams goes on and the other shuts off.
Old Mar 11, 2008 | 12:32 AM
so you replaced the plugs on both sides but only replaced the bulb on one side? alright which side did you replace the bulb on ? just so its a little easier to understand.
so the low beams work on both sides and once you turn on the hi beams the ONE side you replaced the bulb on completly shuts off and the other sides hi beam still works?
sorry your wording kinda confused e but i think im getting it. humor me a little and just elaborate a bit more
Old Mar 11, 2008 | 01:05 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (mikes 95 integra)
check your hi beam fuse. It should be in the under dash fuse box.
Old Mar 11, 2008 | 01:21 AM
H22Ej1's Avatar
Shenanigans
Default Re: (B serious)
check the bulb, swap it with the one you know is working
Old Mar 11, 2008 | 05:51 AM
roe's Avatar
roe
Default Re: (H22Ej1)
X2 sounds like the filament for the highbeam is no good on that side
dlewis2583
Oct 7, 2010 09:34 AM
Yell0w
Aug 1, 2010 08:48 AM
VTECth1s
13
Mar 8, 2008 12:32 PM
92LudeSI
Mar 10, 2004 04:51 PM
98ITR#0020
Jun 22, 2002 09:09 AM
