Question about hi and low beams on my 95 civic!!!!
Well guys i was changing the plugs for my headlights cause they were old and for some reason my lights work but when i turn my hi beams on the light that i changed the wiring on turs off.then when i turn the hi beams off it turns back on.I even put the old plug back on and it still does the same thing.
Re: (HONDACIVC93)
I changed the headlight plugs the ones with the three prongs because they were rusted and old.i only changed one of the lights.The side that i changed turns of while the other side stays on only when i hit the hi beam switch.so only one side of the hi beams goes on and the other shuts off.
so you replaced the plugs on both sides but only replaced the bulb on one side? alright which side did you replace the bulb on ? just so its a little easier to understand.
so the low beams work on both sides and once you turn on the hi beams the ONE side you replaced the bulb on completly shuts off and the other sides hi beam still works?
sorry your wording kinda confused e but i think im getting it. humor me a little and just elaborate a bit more
