Can anyone get me a NEW oil pump off a GSR or Type R???
Seems like these are backordered indefinately.
If anyone has a hookup or has one or can get one please IM or e-mail me.
westkyle@msn.com
Thanks.
If anyone has a hookup or has one or can get one please IM or e-mail me. westkyle@msn.com
Thanks.
Ah man. I didnt know that. I was going to use an R oil pump for my LS short block build up. Is this even recommended, from what I know people say its a good upgrade for the LS pump.
What to do now?
What to do now?
The GSR and Type R pump are the same. They flow better than the B16 and B18B pumps.
If I replace the gear, would a used one be just as good as new? Thanks.
How much are you looking to spend? I was thinking about getting a Toda oil pump and I can order you one when mine is ordered. 22000yen or $190.
Too rich for me. What does a stock gsr or itr one go for anyway? Im too lazy to hit up one of the acura parts retailers.
Could someone post oem part numbers for the 3 pumps in question here.
GSR
ITR
B20
Thanks. By the way Im so
right now, my JE pistons just got dropped off by the UPS guy!! One step closer to 1 bar.
GSR
ITR
B20
I got a GS-R today for 90 bucks...but it was the last one..
next ETA july 15...
I was wrong about the price earlier...this is the actual dealer price...plus tax
next ETA july 15...
from what i found the part numbers are all the same for the ls/gs/gsr/type r/crv
is this true?
go to acuraautomotiveparts.net and if you select any oil pump from 89-95 they are all the same , and 96-01 are all the same part number.
I have a friend that works at honda, got a b16 oil pump -94-95 and it is the exact part number for a 94-95 gsr. Which they have in stock still. the 96-01 are all backordered.
If someone has part numbers please post them thanks
is this true?
I ordered the Spoon pump instead since it's made by Toda and comes complete with the gears and case. Normal price is 26000yen but I got mine for 20000yen ($172).
Ok, so I call the dealer today. TypeR pump is $115 vs GSR $165. Not the same part# the dealer says, which one should I get?
This may help (however, I don't have the # for the B18C5 or the B20)
Rated at 6000RPM
B16A oil pump 53qpm
B17A oil pump 54qpm
B18C oil pump 75qpm
B18B oil pump 53qpm
Wish I knew if the Type R flowed more. The GSR pump seems pretty efficient though.
Rated at 6000RPM
B16A oil pump 53qpm
B17A oil pump 54qpm
B18C oil pump 75qpm
B18B oil pump 53qpm
I work at Acura here in Madison, WI.... who wants one for a little over cost, if you can wait i will hook it up as soon as they are available !
I can order tomorrow if i get some interest ! contact info in my sig...
ON AIM at the moment
[Modified by 94mugenintegra, 1:27 AM 9/24/2002]
$180 for a spoon pump seems like a good deal. you get a new pump & an upgraded gear for less then the cost of a prodrive gear that doesn't include the pump.
