Type R oil pump vs. Gsr Oil Pump
Re: (Cractos)
GS-R and Type Rs have the same damn oil pump. the Pros of the used oil pump..... cheaper den new. The COns.....might be bad ... oil gear warp... about to break........ so Fawk ... go out there and get your fawkin self a new oil pump for around 80-100 bucks... so being cheap and have some extra insurance
Re: Type R oil pump vs. Gsr Oil Pump (boredracer408)
Whats the difference between a 95 b16 oil pump to a 00 Type R oil pump?
the keyway on the crank is different on OBDII motors....
Re: (Cractos)
i used the same type r oil pump that i was using in my all motor type r setup, now im using the same pump in my ls block " but there is only 2000 miles on the pump"
i have very good oil pressure, having no problems,but i still wont buy a used oil pump
